Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
Originally posted by lonix View PostI built this kernel with ap6330 set as wifi and set in device tree also please test it, flash with TWRP on v6
download here
Ill post it to the main page once i can confirm it works
Same issue, no Wifi, no BT
I have a V6 ROM and AP6330 module !
Originally posted by reksio34 View Post
Hi Ionix,
flash back to original kernel download here
then flash this update
That should work, fingers crossed
would be easier to test if i had an i68
Originally posted by natzen View Post@ionix possible to patch kernel x6 to insecure ?
Write access to the system partition is usually blocked by the stock kernel at boot. i need to flash a modified kernel to be able to obtain write access to /system with adb for hdmi state patch .
Try this
adb root
adb remount
This will allow writes to system
I can change it to insecure in the initrd if you like
Can you explain this hdmi state patch to me further, the site you referenced was in korean i dont understand
Do you need writes during early boot?
have modified kernel to always report 0 for /sys/devices/virtual/switch/hdmi/state // this was easy
now I just need to take care of /sys/class/display/HDMI/connected //ok this was easy too
seem's that some apps are looking beyond these two variables for example the "stan" app in australia
ok here it is, https://mega.nz/#!XcIGVKBC!g9KsetZlz...MrtHNkuGJHZvLA
this has
/sys/devices/virtual/switch/hdmi/state = 0
and
/sys/class/display/HDMI/connected = 0
Can you test HBO Go, HBO Now, not sure which app has free streams to test.
It said something about 'external display connected'
Hi Ionix,
Same issue
Hi
I have'nt tested those apps yet as I need a VPN to get access, I did have some success with "Stan" which is a video streaming service similar to netflix,
before i would just get a black screen, now i get a picture but it flickers black, as if the variable is constantly changing
Ionix:
I have followed your work, but I have a box that I could not take advantage.
It is possible both
1.The Zido launcher, work in firmware 201L tronsmart
2. DRM, Widevine L3 support.
I do not know if other people have noticed, but my case is all time my box is hot.
Honestly, I'm tired of the shortcomings of this box.
Programmers like you have my respect.
Go back to the original firmware and try to ignore the stuttering.
Overclocking can burn my processor
Thank you
It is possible both
Thank you
1. The Zidoo launcher is deeply ingrained into the framework so i cant bring it across, ive tried.
2. This is definately possible
If your box runs too hot, you can use the standard kernel
this has
and
and i patch just kernel or boot ,kernel and ressource ?
Originally posted by natzen View Postvery good , i have zidoo 1.0.27 ,it's good for me ? or i update to 1.0.30 before ?
There are currently 1619 users online. 7 members and 1612 guests.
