Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
    Originally posted by axionflow View Post
    Zidoo, no flash problem, perfect,
    Ok I'm going to scale back the overclock on ugoos Rom,
    And make it the same as zidoo rom. I'll update tomorrow hopefully.
      zidoo problem: many times restart or freeze, no move the mouse, Iam flash again,
        I have used the Zidoo rom for my beelink r68 and no problems so far. The activation pop up is gone. However i cannot install the aosp launcher3 from aptoide, installation failed. Otherwise all is great, fast ROM, and all my Kodi issues are gone (audio passthrough works from HDMI, no stutter, no audio out of sync).
        Thanx for your efforts and a properly working ROM. My purchase is gaining again its value.
          Thankyou for your positive feedback try this version
          This is probably why Rockchip set their clocks so low, to keep their yeild up!
          I have put together a package so you can flash the boot.img and resource.img only so you dont have to download the whole rom again
          download (Zidoo ROM ONLY!)
          to install unzip the package somewhere on your computer, drivers are included, but if you've already flashed this ROM most likely you don't need this.
          - enter the AndroidTool_Release_v2.35 directory and run AndroidTool.exe
          - put your device in boot loader mode, plug in the power and USB cable (USB ---> MicroUSB), put toothpick in small hole until you hear a click then press the power button.
          - when you see "Found Loader Device" click "Run"
          your device should reboot automatically.
          sorry for the generic instructions, I wrote them so that I can recycle them in the main post
            I tried your Zidoo ROM on my Tronsmart R68 NON gigabit box and was impressed. Obviously the Ethernet did not work, and a pop up, kept popping up about not valid. Anyway, I like the launcher screen, and a newer version of Kodi. The stock Tronsmart ROM Kodi does not have any DVR clients, but this ROM does. I would love it if you could port this ROM to my NON gigabit box.
              Thanks for the tools. I had no problems installing. The only thing he did not say his instructions was to create a folder and put the boot and resource. The program logic is clear.
              Results:
              1. A more fluid
              2. If there are stutter, specifically in google music, and out of the program and going to google chrome, or opening another application.
              3. The mouse does not freeze
              4. TWRP could enter smoothly, I could clear the cache.
              5. wifi, fine
              6. youtube Android TV is not full screen, but I still like the application and I can not change the quality.
              In summary I understand it much better. I will continue exploring and discussing the positive and what you can improve.
                Hi clarkss12,
                I would like to make this compatible with 100M version, but I don't know what driver your LAN uses, can you post a dmesg?
                do you know how to use adb? here is 15 second ADB installer
                boot your device and plug it in via usb same as when you flashed the rom
                you should have drivers installed because you installed the rom so after you install ADB press windows+r and type "cmd"
                then issue these commands
                Code:
                cd %userprofile%\desktop
                adb shell
                "you should get a prompt like this"
                shell@rk3368_box:/ $
                "if so type"
                Code:
                dmesg > /mnt/sdcard/dmesg
                exit
                " you should return to dos prompt if so type "
                Code:
                adb pull /mnt/sdcard/dmesg
                then you will have a file on your desktop called "dmesg" please add it as an attachment
                  only solution I could find is install an app called "GMD immersive" works quite well
                    Hi ! May I know how to download from MEGA ?
                    Because always show error .
                    Thanks .
                      Thanks .
                      what browser?
                      are you behind any proxy servers?
                        Just download now and OK ?
                          Originally posted by lonix View Post
                          what browser?
                          Google Chrome , no proxy servers , thanks .
                            Hi.
                            Just a note that the OC ugoos rom (UgoosTrons68_Gigabitv2) works fine on my tronsmart meta gigabit.
                              Have you got any extensions that might block mega?
                              Try installing the mega chrome extension
                              https://chrome.google.com/webstore/d...ibnlghod?hl=en
                                Hi clarkss12,
                                Code:
                                adb shell
                                "if so type"
                                Code:
                                exit
                                Code:
                                Thank you, your instructions were perfect. Here is the dmesg you requested. I had to add the ".txt" in order to get this web site to accept it.
                                dmesg.txt
