Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
Originally posted by lonix View Post
So you want widevine support?
Unfortunately without the original source code for this rom, I don't think it will be possible, it needs to be built as part of the rom
look this
In zidoo rom kernel is in boot.img please try this flashable zip
https://mega.nz/#!aBoliLoD!9Mzvzzs_q...xuX3xb8E2WlF_Y
Hi Ionix,
Thanks for your file
Wifi is OK, but BT no !
Can I try to flash kernel.img rom stock to boot.img zidoo rom ?
In your file, you have boot.img, kernel.img and resource.img. If i try to put files from ROM stock into you zip,and flash, the box display zidoo and stop !
Originally posted by reksio34 View Post
Hi Ionix,
I have made a flashable zip with stock kernel
Zidoo has unified boot.img, which contains kernel initramfs and resource.img, the other files are just for redundancy and TWRP needs them too
I tried your flashable zip with stock kernel :
wifi : OK
BT : not OK
wifi and BT is OK with stock rom from tronsmart 205L1 : http://www.tronsmart.com/?p=5133
I extracted files from stock rom .img, it's possible I do something with this files ?
Hi Ionix
just installed the latest Firmware for CSA91 on my tronsmart R68 and the stuttering problem is gone, the firware work smoothly as a previous user mentioned after changing sound device to spdif passthrough. Only issue is the remote control+LED not working. tried flashing the zip with original kernel but then the device will be stuck at boot logo.. This is the link to the firmware
Since the firmware solve the stutter problem is it possible to incorporate the remote+LED and rest of drivers and then well have a perfect firmware??
http://chinagadgetsreviews.com/downl...-tv-box-4.html
Typically boot.img = initramfs, without the correct one the rom doesnt know how to boot
There are currently 1690 users online. 2 members and 1688 guests.
