7th March 2016 ACTIVATION FIX HERE ---> https://mega.nz/#!3cxGxK4b!Te0yyc44B...kjaORYy9EIKxUo
Download v1 -------> Here
Changes:
- Overclocked Kernel and Device tree to suit Tronsmart r68 (IR remote support, Power LED working correctly) - Thanks Geekbox for supplying original Kernel source
- TWRP installed on first boot automatically - Thanks Abdul_pt
- Added YouTube app for Android TV version
- Added Quick Boot as user app
- Added workaround for Zidoo copy protection (its possible for it to not work occaisonally, if you get the "Illegal Activated" message just reboot)
- If anything changes the /system/bin/install-recovery.sh file, it will break the workaround for copy protection.
Download v2 --------> Here
Changes:
- Changed kodi version - had issues with it blacking out randomly, slightly better youtube app playback.
Download v3 --------> Mega Google
Changes:
- Sorry about all the releases - Added launcher3 as a pre installed app, after first boot wait a few minutes then click the O button for home.
Download Here v4 ----> TWRP-Update or Full Rom ----------- Activation Fix
Changes:
- Updated to Zidoo rom 1.0.30 changelog here
- added init.d support, moved scripts there
- In this version I have relesed a TWRP update version as well as the full rom
- To get Fullscreen in YoutubeTV app - install "full!screen" from Google playstore its free and works great
Update Notes:
-There is a bug in the TWRP update caused by me
-TWRP update will NOT format your data.
- Flashing Full Rom WILL format your data.
- Please down load the Activation fix if you get "Illegal Activated" message regularly.
- If you suffer from Pink/Green screen issue then you can flash the stock Tronsmart Kernel available here this is a flahable zip.
- If your rom freezes and locks up, please download and flash the "tame" kernel here
Download Here v5 ----> Full Rom Only
Changes:
- Brand new kernel, better YouTube performance, instead of stutter only slight pause
- fixed activation, no need to flash zip
- Fixed Bucktooth, err Bluetooth.
- Downgraded Kodi to 15.2
Update notes:
- enjoy
- My experience with YouTube stutter is caused by Google updates, for proof, flash this image, play YouTube videos to test,
then add Google account and test again.
- If you want to keep your apps make a backup of /data with TWRP before updating, then restore it afterwards, or use TitaniumBackup (play-store)
Download Here v6 ----> Flashable .zip Full ROM
Changes:
- Added L3 WideVine support.
Update notes:
- Accidentally broke HDMI-CEC will fix in future update
- If you have issues with freezing / crashing please install THIS kernel - DON'T USE V4 KERNELS, THEY WONT WORK
- If you cant enter recovery use the method below in general notes but unzip the files from the above file
Download Here v7 ----> Flashable.zip(removed) Full ROM
Changes:
- Fixed HDMI-CEC
- Fixed Kernel Bugs, remove over-clocking.
- Added preinstall apps - Netflix, ES File Explorer, Kernel Auditor and updated OGYouTube to 1.2
- Hide HDMI status - /sys/devices/virtual/switch/hdmi/state = 0
Download Here v8 Rev3 ----> Flashable .zip Full Rom
Changes:
- Kernel Tweaks and updates
- Now boots without HDMI plugged in
- Updated to ZDMC aka Kodi16, this version has "PVR addons", I have only tested tvheadend htsp.
- Fixed ugly logo's
- Full ROM no longer uses integrated boot.img, this allows easy kernel flashing for use on other devices.(eg z4)
- Special thanks to MaximRY for the updated TWRP for unified partition ROM
Instructions:
- Please Install only over v7 rom, older versions may work too but I haven't tested.
- Copy .zip to USB stick or Internal Memory
- Reboot to recovery using quickboot.
- Flash the .zip
- on first boot please wait a few minutes for kodi to install, then reboot your box, kodi may give message of not responding otherwise.
Download Here v9 Rev2 ----> Flashable Update, Full ROM, Kernel
Changes:
- Bring ROM up to 1.0.33 base
- Does not affect kernel in any way, will not overwrite your kernel if you have changed it. (Flashable update)
- Seperate Kernel update, for compatibility with other boxes, flash separately (Flashable update)
- Fix ROOT (Flashable update)
- Added CONFIG_IP_MULTICAST (Kernel, FullROM)
Instructions:
- Install over v8r3, Please be patient, this replaces every file in /system and there is no progress bar, on first boot the cache needs to be rebuilt (Flashable update)
- reboot to TWRP recovery and flash (flashable update)
- If you are on the original v9 flashable and you want to fix root without a large download, download the official SuperSU boot to recovery (see below) and flash.
- See Below, Please allow several minutes on first boot for apps to install. (Full ROM)
- Recommend to install FullROM but am providing TWRP Update as well (YMMV)
Known Bugs:
- If you reboot to recovery with USB device inserted TWRP may sometimes freeze.
- Feedback please
Download Here v9 Rev3 ----> Flashable Update(/system only)
Changes:
- Bring ROM up to 1.0.36 base
Download Here v9-5 ----> Full Rom
Changes:
- 1.0.38 Base
- Kernel Updates
- ZDMC 16.1.1 from Zidoo
Installation Instructions
I don't want to do a big write up on how to install this ROM, so please follow the instructions from Tronsmart just substitute the my .img file, download their update package here
HOWEVER... there is one exception to their instructions which is how to get device into bootloader mode.
To enter BOOTLOADER mode:
- Plug in Power and USB cables then using a toothpick or other thin item press and hold the button inside the small hole and then press the power button.
To enter RECOVERY mode:
- Plug in Power cable then press the power button first, then immediately press and hold the button in the small hole.
To Bring this ROM to your device:
- Find the Stock ROM from your specific device and extract the kernel.img and resource.img using android tool
- Use android tool to flash the kernel and resource to their relevant partitions
