Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
Originally posted by ontherocks View PostWIth 1.0.38 on Nexbox Z68, ZDMC always crashes on selecting a video file.
https://mega.nz/#!HldiWTIa!hQgNFYe2D...nIZrKTfquDIC1wRegards, STZO
Originally posted by mastro7712 View PostI uninstalled ZDMC and all previously reported problems are gone !!! Now the ROM works perfectly !!
SOLVED!!!
Regards, STZO
Hello,
Looks like I made a bad with my latest release
links have been removed from last post
here are the new links:
Flashable Update
Full ROM
This should fix a few issues with kodi due to me not updating certain files in /system correctly, and should now support Beelink 2.4ghz WiFi out of the box with no modifications.
Please accept my apologies.
Hi Guys,
Please report your experiences with this new 9.4 rom! In this rom Zidoo changed to the same audio processing path (RK1000 instead of I2S) that Nagrace did, where HD audio passthrough does, but the PCM to DD transcoding doesn't work. How is it with this firmware?
Also I'm curious how the software decoding process increases the CPU temperature?
Thanks for all, STZORegards, STZO
https://mega.nz/#!LI4TiQpR!RSNwXmlBJI1AYZWjdVrKiCd7VH9QLgVn4HyonDB YfJs"]Flashable Update[/URL]
https://mega.nz/#!WYIFjISB!OxsufamGspLGGVVIP-lsClD-OA56FOXRXnRPavqKvjI"]Full ROM[/URL]
Flashable Update
Full ROM
It was also arranged that the Bluetooth and 5GHz network that did not work !? In addition, the slowdown of the image and stuttering were eliminated !? before flashing I would be a little bit more secure ... ok !? and I would avoid re-install all the app, so dear friend STZO, if you explain to me well as just flash the update is not all Rom me I would be grateful ....Regards, STZO
Originally posted by ukmark62 View Post
Thanks for this. Does this fix the stuttering every 40 seconds or so when using auto frame rate switching and playing back 23.976 movie??
Regards, STZO
As far as I know, the difference between the two versions - as the KODI installation is concerned - is in the librkffplayer only.
There are currently 1902 users online. 0 members and 1902 guests.
