how can i unroot this firmware or could i..?
Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
I have the tronsmart 100Mbps and installed your latest modded Rom using my kernal per your great instructions. Everything is working great so far, stock remote works, WiFi and Ethernet work. I used your twerp recovery to install the activation fix zip, but I am still getting the activation illigal popup. Any ideas?
Edit: Went into system buildprop and removed "o" from the device name Zidoo x6 pro. Seems to work, no more popups.Last edited by clarkss12; 29 April 2016, 02:10.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by l30ns View PostYes! Your kernel v8 (BeeZid-Kernel-v8.zip) makes BT and 2,4GHz WiFi work nicely out of the box w/o any file replacement or nvram_AP6330.txt renaming.
Please test this kernel, TWRP flash... sorry this is going to be trial and error.
edit: try link again?Last edited by lonix; 29 April 2016, 08:42.
Originally posted by lonix View Post
https://mega.nz/#!qMZ3TYCR!zE_PTaTYrRAdefZOu6inGxm1XzgLqaRBKsIMQaH 1y-0
Edit: Much better! Thanks!Last edited by l30ns; 29 April 2016, 11:51.
lonix. Kudos on 9v2! I always like TWRP recovery. ZDMC on this ROM gives the i68g a stutter free Kodi. It has some minor issues with audio offset on some videos, but is easily adjusted. Fixing BT & Wifi is pretty straight forward and well documented. Your work is appreciated.Nvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
I am with my question here in a false portal, but feel very cared for. Does anyone know an alternative for Android in the way of "DNS Jumper". Important would be the automatic start when starting the Android box and software. Besides these, a program would be interesting for me, as DNS Leak fixed. Thanxs and Greetings from Downtown Germany (Berlin)
Originally posted by lonix View Posthttps://mega.nz/#!qMZ3TYCR!zE_PTaTYr...RBKsIMQaH 1y-0
Originally posted by lonix View PostDid you say the Tronsmart kernel works out of the box?
Originally posted by lonix View PostSorry I meant tronsmart stock kernel.
There are currently 2695 users online. 0 members and 2695 guests.
