How should I use this tool !?
Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
Originally posted by Stzo View Post
You can fix the MAC address with this tool:
and so you can set fix IP address for the wifi too, even if you use DHCP as well. In thi later case the DHCP server shoud be set to aasign the same IP to this device.
The MAC fix should be set for both ethernet and wifi. Read funcion probably will not give you any response, just after you have a valid number stored previously.
Otherwise, this situation with your box is completely strange, and noone else have experienced such behavior yet.You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Originally posted by lonix View PostHi everyone,
anyone still here?
I would like some people to test this new release, v9-4+ includes kernel.
The 9-4+ works nicely with no bugs so far (been using it for 3 days already). It seams a bit snappier too. Thanks for the job done!
Just wondering --> Have you discarded the idea to make the kernel auto-detect both BT, 2,4G &5G Wifi on Tronsmart R68.
9-4+ no longer auto-detects wifi+BT of any sort and one needs to revert to file replacing fix to get them running again.
P.S. Do I lose all your kernel optimizations if I flash Resources image from the original firmware? Is there any other simple way to get 5G running without missing out on your Kernel goodies?
5g on beelink is probably something I can only solve with access to the hardware.
The beelink resource.img is probably not compatible with my kernel, different revision, I am actually using a marshmallow kernel source.
I did have wifi and Bluetooth working in a previous version but it seems that i broke it with my updates.
Try this version, https://mega.nz/#!CM4zzKLa!nP4tlsWvb...P3fYFLVbRQ8m6c
Sorry no 5g yet
Originally posted by mastro7712 View Post
How should I use this tool !?Regards, STZO
Look at the pictures .... this is the address that changes when I connect hotspot of mobile phone and that gives me the error !!!! the MAC address of the Ethernet card and that the card does not change WIFI !!!! It is absurd this situation !! and in addition this address changes each time you reboot or shutdown drl box !!!! I do not know what to do....Regards, STZO
anyone still here?
Changes:
- Based on Zidoo 1.0.38
- New Activation patch thanks STZO.
- many kernel fixes, too many to post here.
- removed most unnecessary apps and bloat.
Install using TWRP over previous release v8-3 or above, Full ROM Available Here
Known Bugs:
- ZDMC may not play video correctly unless you disable rockchip acceleration.
- Please report your findings.
- If you continue to have problems with ZDMC you can revert to the previous version available here
Hi Lonix,
Can I flash my Z68 with your new ROM V9-4 with kernel? or do I need to replace with the original Kernel from Z68 stock ROM afterward for the remote control to work correctly?
Thank you for your help and times.
KN
Originally posted by [email protected] View Post
Hi Lonix,
KN
Hi Lonix,
KN
If you are using the TWRP zip file you can replace the kernel.img and resource.img with 7zip or another archiver and then flash to your device
I'm not sure if the tronsmart kernel will even boot the z68 so it's a good idea to flash the z68 kernel and resource.
Hi Lonix,
I got it and thank you for your times
KN
https://mega.nz/#!zEgQnRiZ!UO1eERyDb...szSeSw_MiutGrE
Here is the original.
Try restoring this first, should stop the messages
I have write FullRom 9.4 but the "illegal activation" error ( the same of mastro7712) hasn't gone away.
Also notice that with 9.4 there isn't TWRP as recovery.
Hi Lonix,
KN
Hi lonix. I've seen that you've enabled CONFIG_IP_MULTICAST in your v9 Rev2, which is something I've been hoping to find for my NexBox. Unfortunately, none of the otherwise useful and well worked roms related in the Nexbox forum seem to have UDP multicast enabled. So I think I'm going to give a try to yours. In that case, should I just install your full rom or what?
Thanks!
Originally posted by palimpodio View PostHi lonix. I've seen that you've enabled CONFIG_IP_MULTICAST in your v9 Rev2, which is something I've been hoping to find for my NexBox. Unfortunately, none of the otherwise useful and well worked roms related in the Nexbox forum seem to have UDP multicast enabled. So I think I'm going to give a try to yours. In that case, should I just install your full rom or what?
Thanks!
Originally posted by tommeletbone View Post9.4 TWRP is missing
There are currently 2518 users online. 1 members and 2517 guests.
