Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
TronZid v9-5 Bugfix release
fixes:
- Install TWRP Correctly
- Install ZDMC 16.1.1 by default
- Some Kernel Fixes
Full ROM:
https://mega.nz/#!rQoB2aaR!-wd2nEVOO...eQsDYFMWC4FAQA
Originally posted by lonix View PostTronZid v9-5 Bugfix release
fixes:
- Some Kernel Fixes
Full ROM:
Thanks for the update. Would you happen to have a kernel and resource files available in a zip that can be updated via TWRP for the Zidoo X6 Pro?
Originally posted by minixfreak View Postis there anyway of building a kernel off the tronsmart 209L1 so we can have 5ghz wifi back and enjoy your beautiful rom as well?
Originally posted by clarkss12 View PostI made a video on how to extract your kernel and resource img files on your stock rom and use them on other modded boxes.
Thanks for the tutorial. I don't know what it is but for my Zidoo X6 Pro they release OTA's not IMG full rom image files. I'll keep looking in the OTA zip file for the kernel and resource files base 1.0.38.
Originally posted by androidfr33k View PostGuest
How are you. I would like to try your latest rom. Can I use the kernel you had a few versions back for the ZIdoo X6 Pro or has Zidoo updated their kernel as well as their base rom?
If not
Download the OTA file from zidoo, then on your computer unzip the file.
Flash the boot.img that is extracted , I think you can flash it using TWRP, if not use Android tool.
You can give it a try, it should work
If not
Tried both methods. After it boots I have a blank screen with only the time flashing. I can just flash the stock Zidoo rom and do an OTA update and then use their root installer they have a link to. I actually already tried that and it worked fine. The only thing I have no idea how to get TWRP installed. I did try flashing recovery.img from your latest rom using Android Tool 2.35. Its says ok in the end but I can only boot into android revovery not TWRP? I also tried installing twrprecovery.img using AndroidTool after renaming twrprecovery to recovery.img and again it only will boot to the stock android recovery partition not TWRP?
Just cannot win at all with all the road blocks I am encountering having a Zidoo X6 Pro device.
Edited:
Got it to work but had to update TWRP to 3.02 and Supersu to 2.74 beta and after that I was able to install the boot.img from Zidoo OTA 1.0.38 update as you had explained. Its the oddest thing that the Abdul 2.8.7 version did install the boot.img but did not seem to work after boot. ANyhow all good now. Thanks!!
http://freaktab.com/forum/tv-player-...=1466986086957
Edited Again:
I must have done something wrong the first time so I decided to start over since it was bugging me so much. It worked exactly as you said from start until finish using TWRP. I just forgot to choose boot partition the first time so it has nothing to do with a later version of TWRP or Supersu.
There is a minor bug in TWRP for at least the Zidoo X6 Pro. The controller does not work nor does the USB without powering it with a USB to PC and device then keyboard mouse and USB flash drive will work. Same with updated 64 bit version of TWRP link above.
Hi Lonix,
Thanks very much for the 9.5 update!
Has there been some improvements made in relation to playback of 23.976p files when the screen is set to 24Hz?? This has been a long standing issue with Rockchip devices where there is a micro stutter every 40 seconds or so, as I believe Rockchip don't speed up the audio/video to match 24p like Amlogic devices do and this causes the hiccup (it's documented all over the web).
The reason I ask is that it appears to me that this stutter is now practically gone. I have certain sections in different movies where I used to notice this stutter and now the stutter has either gone or is significantly reduced. Is it maybe that the zidoo firmware has been improved in this area - I can find no mention of it being fixed anywhere on the web. Maybe you have done some changes to the kernel in this area??
I should state that this improvement is apparent whether I use ZDMC v16.1.1 or stock Kodi v16.1 and auto refresh rate switching must be turned on (I have an addon that does this refresh rate adjustment for Rockchip devices using stock Kodi - ZDMC performs auto refresh rate adjustment without this addon.)
Any thoughts?? TIALast edited by ukmark62; 29 June 2016, 12:01.
Any thoughts?? TIA
In previous versions of ZDMC I noticed that the sound is played with the original speed (without any modification), and the video frames were adjusted (e.g. corrected in every e.g. 40 second) to the audio stream. That resulted in little varying lag between the video and the audio. The eaxct solution would need to play the video with the most accurate framerate, and resampling the audio to get the accurate synchrony between them.
Probably, the video decoding were done by the hardware module of the SoC, and the audio play was realized by software decoding. the audio lag vas approx. 0.3 sec (8-10 frames) in this way. The lag is different from video to video, depending on the video encoding system and the resolution of the video file.
In the latest ZDMC it seems, the video decoding they have moved into a software solution, which would allow them to correct the lipsynch. Maybe, however, the only difference is that software video decoding takes more time than the hardware solution, and so the lag seems being lower. The difference between the decoding times of the different video files is probably remained, anyway.
Otherwise, there is not clear to me, if a TV sets supports 24 fps HDMI input, is it 24fps in real, or 23.976 fps actually? Maybe two TV sets work differently. Who can check that exactly? Did you see a TV set with 23,976 fps support?Regards, STZO
lonix
Well another question for you. My remote controller. mouse nor keyboard will not function in TWRP until I power the USB port either USB from PC to device or a powered USB hub, but controller still does not function. Is there something you tweak in the kernel to get the controller and USB to work in TWRP or is the TWRP source version modified and re-compiled for Tronsmart?
There are currently 2253 users online. 2 members and 2251 guests.
