Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
    Hi lonix! First of all thank you for a great work. I tried the firmware 9.5 and was quite satisfied. At least, the issue with sound distorsions while using SPDIF seems to be gone.
    Actually, my question is: how can I change system settings to turn off usb ports when putting tv box in standby mode? Currently the box goes to standby, but ports seem to be active - my external hdd continues working though on the stock firmware it turned off together with the tv box. Please advise. Thank you in advance.
      I read all the post because I have a Beelink i68G (1000mbs) and I want to flash this rom to solve stuttering problems, but I have one question. Maybe someone can help me:
      - Can I flash FULL ROM from last ROM I have without any update, and, Do I need to flash kernel and resource.img to install that?
      - In case I need to flash kernel/resource, I read I can get kernel from my last official ROM using Factory Tool, but, what I need to do first after that? Flash new Modded ROM and then kernel and resource.img?
      Im little new flashing modified ROM so thanks for your help and sorry for my poor english.
      Great job!
        Hi
        Yes,that is what you must do.First .img then r & k.Dont forget to Backup your Data and Apps to Sdcard.More Info.Ask.
        good luck
        gefattern
          Hi
          good luck
          gefattern
          Thanks! Only last question, can I flash kernel from v9 or I need to flash kernel from my stock rom? and whick program is better for that, android tool o factory tool?
          Edti: Windows 10 dont recognize me i68G in android tools, any idea? thanks!
            Hi mambanegra24
            1.Rescouce & Kernel from Stock.
            2.Androidtool / Factorytool is more for unpack and customization / look in AndroidTool on 3 Tab "Advanced Function" Unpacking possible too / to find in Outputfolder of the Tool.
            3.Win 10,i thing Driver Problem,read the whole Thread to find Info,if possible for flashing use Win7.
            4.Did you all correct while flashing.Do you know how to flash RKDevices ??? please answer,did you install the Drivers ? Connect it once without Power on.
            nice Day
            gefattern
              Hi mambanegra24
              nice Day
              gefattern
              Thank you for help, I finally do it and works well! i didnt change kernel/resource and is working well but wifi and bluetooth doesnt work. I try to solve them with a fix and if I can fix problem I try to reinstall ROM with kernel/resource stock
                Hi mambanegra24,
                the reason why Wifi not work is the wrong Kernel&Recourse,flash them to the Rom and it mostly work good.There is a fix for the Wifi by changing the AP633...file,but k&r is i thing better.Fix is only for 2.4 Wifi.
                hope you can fix it nice Day
                gefattern
                  Hello, i installed the tronzid 9.5 full rom on my device. I get a lot of app crashes and also the system reboots (crashes) without notice. any help? by the way - no busy box pro for this device...
                    Hi lonix, i've upgraded my Tronsmart r68 1g from Trozidoo full rom 9.3 to 9.5 and since then it won't recognize any of my sd cards. I've also tried formatting them to all file systems options (FAT,FAT32,exFAT and NTFS) w/o success. Any solution to that?
                      I still have problem with the ACTIVATION), I have to put the ACTIVATION FIX every 3 or 4 days sometimes less.
                      you have a definitive solution please?
                        I installed this ROM but I have a problem. My box shows it has only 4GB internal storage. It's possible that I had this issue before this Rom I'm not sure about it. Does anyone know what sould I do?
                        Thanks a lot,
                        Oliver
                          Originally posted by Csupi003 View Post
                          Thanks a lot,
                          Oliver
                          It's normal.
                          The storage is split between userdata where you can install apps and user partition whre you can copy files.
                          The Android OS also uses 1-1.5GB of space.
                            Yes but I think I should have 16G instead of 4G on the picture.
                              It is possible to have a version of 9.5 with a table of frequencies larger (to overclock). Or give me some advice to do it myself.
                              With some changes VCore and memory For better energy management and Increase in temperature.
                                Version 1.0.42 of ZIDOO X6PRO is out.
                                Do you have plans to port it for our box?
