Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
Originally posted by myshedy View Postwhen i flased v7 ,after the boot , the device shut it self down.
and i tired removing power and the same happen the led turn blue and then dead.
after flasing from my pc the orignal kernel everthing working
I think I'll have to remove the download
I think it won't boot unless hdmi cable is plugged in
I am currently running v5 and the HDMI audio passthrough is working better than any other rom I have tried but I still get drops in the audio for a split second quite often (every 10-15 seconds). It seems to be worse on DTS-HD than on DTS or Dolby Digital. Does anyone else have this issue? Is there anything I can do to fix it? Does the latest version resolve the issue?
Originally posted by gotpaste View PostI am currently running v5 and the HDMI audio passthrough is working better than any other rom I have tried but I still get drops in the audio for a split second quite often (every 10-15 seconds). It seems to be worse on DTS-HD than on DTS or Dolby Digital. Does anyone else have this issue? Is there anything I can do to fix it? Does the latest version resolve the issue?
Originally posted by lonix View Poststrange, everything is still working here, can you check the file /system/bin/preinstall.sh
it should read as follows the bit thats important is the 2 iptables lines, this blocks the rom from connecting to zidoo's server
Code:#!/system/bin/sh iptables -A INPUT -d 203.90.239.13 -j DROP iptables -A INPUT -s 203.90.239.13 -j DROP echo "do preinstall job" >> /data/log.txt touch="/system/bin/touch" PM="/system/bin/pm" if [ ! -e /data/system.notfirstrun ]; then APKLIST=`ls /system/preinstall/*.apk` rm -r /data/dec_out.h264 rm -r /mnt/sdcard/contorl for INFILES in $APKLIST do echo setup package:$INFILES >> /data/log.txt $PM install -r $INFILES done touch /data/system.notfirstrun fi echo "preinstall ok" >> /data/log.txt
There are currently 1913 users online. 0 members and 1913 guests.
