Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
    Hi ! Could you upload for other cloudy space for activation issue?
    Zidoo_X6 Pro pop up error
      Will you have these fixes on the OP page, unless you incorporate them in the next firmware update zip? For example the registration file, for all other fixes throughout this thread would it be too difficult to have a link for them on the OP page? If not then we can always use Search
        Originally posted by lonix View Post
        Not sure why, please try the stock kernel version.
        https://mega.nz/#!XRYCjYoY!nm30Z0IUZ...BS_giwWisCPshc
        Hi, I downloaded the zip but there aren't "instructions".
        Please, can you tell me how to install the fix?
          Could you please build his rom with AP6630 wifi .... i have tried the wifi fix but only get 2.4ghz which is very poor speeds ... and ethernet is not an option for me .... so PLEASE PLEASE Make this rom with AP6630 so i can have the 5ghz band back ...... Im sure alot of us would be very greatful
            i mean AP6330 thanks again
              I have TWRP on my box. First time flash this rom, which version I need to start, from version 7 is ok or use version 4 twrp one?
                v8 with registrationFix is working great. Registration error gone.
                Thanks for the good work and time you have given this project.
                  Start from v7
                    did v7, just got 8 penguins. any other way
                        What box is yours?
                          the new z68, use wasser's rom. works, but no internet. change the backup kernal file back. still no internet
                            hi
                            lonix because I have the green/pink problem I always need to go back to tronsmart original kernel file ( that you make me... )
                            when I tried to burn v8 ( 1 ,2 or 3 ) the box work but the green/pink problem return...
                            so I flash to original kernel. but with v8 the box wont load..... black screen
                            I needed to re-flash the firmware and erase the box...
                            there no fix for the green/pink with out the original kernel?
                            you are a genuis can you find a fix????
                            and again your the best!!!
                              Hi Lonix,
                              v8 has been erased from the main post
                                Originally posted by zivco View Post
                                Hi Lonix,
                                that is strange, maybe I stuffed it up somehow
                                v8-3 link is here https://mega.nz/#!zVAQCITD!9wmeoR6w9qqme1X1QXNPQ_48pep063EaaHslVPp qeNI
