Ah! In that case I am affraid this ROM won't help me. The main reason (apart from liking the ZIDOO launcher) for trying this ROM is because I hope it will be a fix for my HDMI-handshake (pink/geen issue) problem. And that fix is done somewhere in the kernel, isn't it? Your original ROM was based on a Tronsmart kernel which has a fix in it. If it is necessary to use the original Z4 kernel to get it working on the Z4, the pink/green issue will stay. :-((
Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
If somebody need this - resource with turning of fix and kernel from 25.01.2016 stock firmware all in 1 archive for Z4 - https://mega.nz/#!3tMBCRBJ!37J1ZCogc...bPiGv0FMO8RcDw
Originally posted by maximry View PostIf somebody need this - resource with turning of fix and kernel from 25.01.2016 stock firmware all in 1 archive for Z4 - https://mega.nz/#!3tMBCRBJ!37J1ZCogc...bPiGv0FMO8RcDw
Originally posted by myshedy View Post
thanks!!!!
working perfect!!!!
your the best!!!!!!!!!!!!!!
I tried the 206L kernel on my Beelink i68 ( v8-3 + activation fix + WiFi fix ) and the stuttering comes back, so I refresh v8-3 and activation fix, now everything is fine again, Just to let people know.
I am a Chinese player, zdmc set Chinese menu, some of the menu can not be displayed in Chinese, is blank, to continue to play when there is no time to choose, you must use the menu key to select the blank play
In addition, the installation of Kodi and vidon is the same as the menu problem, it may be my core problem, I hope lonix can help solve, thank you very much!!!!!!
Originally posted by 251643711 View PostI am a Chinese player, zdmc set Chinese menu, some of the menu can not be displayed in Chinese, is blank, to continue to play when there is no time to choose, you must use the menu key to select the blank play
Did you try to change the stock skin font to Arial which is used to display other languages? I can use both 繁體和简体.
Chinese Add-ons
Author:Taxigps
Version:1.2.0
Chinese Add-ons
Chinese Add-ons
Author:Taxigps
Version:1.2.0
Chinese Add-ons
This is definitely installed, not installed how to display Chinese, and now the problem is that some of the menu does not display Chinese, not completely does not display Chinese
Originally posted by Will2 View Post
Here are the steps to get Ionix Ziddo or TronZid to work on Z4. Haven't had time to test everything out.1. Flash https://mega.nz/#!HJZ0WLCZ!pLbeW8n_A...VQH185whUrJeoa vF54Resource - Stock Z4 Resource or (http://www.mediafire.com/download/hz...g/resource.img)
2. Immediatly flash using AndroidTool_Release_v2.3
Kernal - HPH_NT-V8_v1.2_by_mo123Adb root
3. Once Zidoo loads run this cmd through adb on your computer
Adb remount
Adb shell chmod 755 /system/bin/preinstall.sh
There are currently 2656 users online. 1 members and 2655 guests.
