Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
Originally posted by Code-Sniper View Postunfortunately does my resolution in the software version is incorrect. Wallpapers are represented too large. Do you have a tip? Greetz from Berlin..( sorry my english is not good)
https://drive.google.com/file/d/0B1Z...ew?usp=sharing
https://drive.google.com/file/d/0B1Z...ew?usp=sharing (Video)
Originally posted by lonix View PostGuys,
Im releasing TronZid-v8-FullROM.
Before i add it to the main post, could someone please test this on a z4 device and let me know if the 8 penguins has been resolved
This includes latest kodi and activation fix, It also contains an updated TWRP which was kindly provided to me by MaximRY
Thank you to everyone for your continued interest in my work.
After first boot I see your Lonix Kernal screen. Then boot loop after. After unplugging power and plugging back in it just boot loops over and over.
it was the false Post Replied **sorryOriginally posted by Will2 View Post
After first boot I see your Lonix Kernal screen. Then boot loop after. After unplugging power and plugging back in it just boot loops over and over.You may only view thumbnails in this gallery. This gallery has 3 photos.3 PhotosLast edited by Code-Sniper; 10 March 2016, 17:04.
Brush your new V8, my rk68 RKM no penguins appear, there is a green robot will automatically shut down after a while!!! Hope to solve, thank you!!!!!!!!
My English is not good, I am sorry!!!!!!!
first thanks lonix for your great work!
lonix im having problem with power-off when connected via lan, when i select power off it just restart my box i try different apps for turning off the device but it simply restarting the box. i dont have this problem when im using wifi. can you have a look on this? im using orion r68 with your latest rom.
and im having same problem too with code-sniper of image being cropped when setting as wallpaper... i tried wasser firmware before that fixes it but not sure what version i used.
Originally posted by lonix View PostOk, Please try this version
I seem almost to reflect, I also continue to test, although you ignore me
I'm downloading the firmware now. I suggest you do the same and try it out. Both of us described the same scenario not sure Ionix should address every post. Will post back after I try it out.
Nice, that is good that we have a boot, i made a mistake with the rom /system/binpreinstall.sh should be mode 755 and i accidentally left it 644. You can fix in adb
Adb root
Adb remount
Adb shell chmod 755 /system/bin/preinstall.sh
Can you send me z4 resource.img please
There are currently 3360 users online. 1 members and 3359 guests.
