Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
    Originally posted by GZD View Post
    the new z68, use wasser's rom. works, but no internet. change the backup kernal file back. still no internet
    Have you tried Super Celeron's custom rom?
    http://freaktab.com/forum/tv-player-...464#post559464
    Could you please try it and let me know if it works?
    do you happen to know what wifi chip this device has?
    does ethernet work with wasser rom?
    also can you try flash stock Tronsmart rom?
    available for download here http://www.tronsmart.com/?p=6770
      Originally posted by minixfreak View Post
      Could you please build his rom with AP6630 wifi .... i have tried the wifi fix but only get 2.4ghz which is very poor speeds ... and ethernet is not an option for me .... so PLEASE PLEASE Make this rom with AP6630 so i can have the 5ghz band back ...... Im sure alot of us would be very greatful
      please try flash this .zip with TWRP,
      This should be considered as experimental untill confirmed to work
        Originally posted by myshedy View Post
        hi
        lonix because I have the green/pink problem I always need to go back to tronsmart original kernel file ( that you make me... )
        when I tried to burn v8 ( 1 ,2 or 3 ) the box work but the green/pink problem return...
        so I flash to original kernel. but with v8 the box wont load..... black screen
        I needed to re-flash the firmware and erase the box...
        there no fix for the green/pink with out the original kernel?
        you are a genuis can you find a fix????
        and again your the best!!!
        Done!
        Here, I tested it and everthing.
        Flash v7, then v8-3, then this kernel
          Originally posted by lonix View Post
          Done!
          Currently I am using an other ROM (until the moment I am able to flash your ROM) on my Z4. Can I flash this kernel to check whether this is a solution for the pink/green issue on my Z4? Or is a kernel hardware/brand dependent?
          In case of flashing a kernel, is it necessary to flash it to the right position/segment in memory (using the Android tool) or will it 'land' automatically on the right spot?
            Ok, so there is a zip to fix the Activation issue at the top of the post, but what do I need to do to make it work.
            Thanks...
              Thanks...
              Download the zip file and put it in /sdcard, boot into TWRP recovery and install the zip file, that's it. Works like a charm
                You can flash these images but your rom probably wont boot, if you get the tronsmart logo, that's a good sign that it works.
                As long as you assign them to the right partitions it will read the position from the device
                  Android tool download https://mega.nz/#!GB5m1R4Q!cq-Gt8hN_...BMK4ETt1bVhbuQ
                  Please try with android tool flash recovery.img from your stock rom.
                  Do this after flashing v7 rom
                  to extract this file, download stock rom for your device
                  Open android tool, goto advanced function tab
                  In the box marked firmware, load stock rom file.
                  Click unpack.
                  When finished
                  Goto download image tab
                  Unselect all boxes except recovery
                  Click the empty column with ... Three dots at the top on the recovery row. Select the recovery.img from the \output\Image directory.
                  Please report back with your success
                  Can I use a custom ROM Celeron, but now according to your yesterday's boot screen output without brush method. I give you my REC. Hope to help me, thank you!
                  Only Chinese network, I hope you can download http://pan.baidu.com/s/1kUqcMer
                    On the ROM that I can run on RASHR. Prompt does not support my device, you need to restart, restart after entering the rec can not enter the rec
                      @Ionix, thanks for your hard work.
                      Is version 8 ONLY for TWRP or can I use something else to flash. ( I don't have TWRP) . thanks
                        If it is an img file then it is a full ROM. Use factory tool to flash.
                          Originally posted by razor_x View Post
                          Hi!
                          Great job with the v8 Zidoo custom ROM! However, I've detected a few issues after one day of use:
                          - Lock screen does not work, even though the "Lock screen on boot" was selected, and there is no way to force the lock screen anytime. This is a big problem when multiuser is activated,
                          - HDMI passthrough does not work so far. It neither worked with the official ROM. I have my Samsung TV connected to an Onkyo A/V receiver with HDMI ARC and I successfully play videos through DLNA from TV itself, so Dolby Digital and DTS are passed through HDMI to the receiver. But with my Tronsmart, sound is muted when I enable sound passthrough in ZDMC. I had previously set HDMI bitstream in Settings.
                          Any suggestions? I am using Google Now Launcher, in case it helps.
                          Thanks in advance!
                          Please, someone with Tronsmart R68 Meta can try multiuser and audio passthrough options? Both did not work for me. When you have 2 users or more it's impossible lock screen appears even though you have set up a pin code or pattern. On the other hand, dolby digital or dts audio never passthrough to my TV although you have checked HDMI bitstream in Android Setup and audio passthrough on Kodi.
                          Regards!
                            how to get immersive mode for all app, the nav bar always there, could not hide it. kodi no problem.
                              Try the app called full!Screen by tsorn
                                I can't get my box out, wait!!
