Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
    ok guys, here you go.
    csa91 rom with my kernel. TWRP installed on first boot
    Also Just Uploaded V5
    "Tronsplant your rom"
      Originally posted by mmthabet View Post
      Hi Ionix
      just installed the latest Firmware for CSA91 on my tronsmart R68 and the stuttering problem is gone, the firware work smoothly as a previous user mentioned after changing sound device to spdif passthrough. Only issue is the remote control+LED not working. tried flashing the zip with original kernel but then the device will be stuck at boot logo.. This is the link to the firmware
      http://chinagadgetsreviews.com/downl...-tv-box-4.html
      Since the firmware solve the stutter problem is it possible to incorporate the remote+LED and rest of drivers and then well have a perfect firmware??
      In Your firmware:
      Build number: rk3368_box-userdebug 5.1.1 LMY48G eng.edwin.20151113.154644 test-keys
      This is latest:
      http://chinagadgetsreviews.com/downl...-tv-box-3.html
      Build number: rk3368_box-userdebug 5.1.1 LMY48G eng.edwin.20160107.180142 test-keys
        hi
        lonix is v5 version kernel include green/pink fix?
        or need to flash tronsmart kernel?
          Originally posted by myshedy View Post
          hi
          Im using newer kernel sources, can you test for me.
          If it has problem just flash stock kernel
            Originally posted by axionflow View Post
            Installer, waser firmware in R68 Meta (2,16)but still the problem of stuttering and the colors look dull. The intenet is super fast, I think it is the fastest out there.
            I'm reading about DRM in boxes android. In Waser Rom (Google Widevine DRM moudlar this in Stage 1, while in Zido firmware does not exist.
            This is very important because the higher the level (level-3), we see better quality content, Netflix and Google 4k movies or other apk
            Info :This apk :https://play.google.com/store/apps/d...idfung.drminfo
            Example: WeTeck have google certificate, buy the level is 1. Is no much, i don't like this box, my transmart R68 Meta is better. (software is trash)
            Ionix, is possible level 3 in zidoo firmware? or same level 1. wasser rom?
            Thank You
            Wasser and my HPH RK3368 ROM has DRM Level 3 to use Google Play Movies and other streaming apps.
            You need Level 1 for HD Netflix.
            The lower the level the better not the other way around.
              Thanx Ionic and androidgadget11 will try those with Ionic kernel
                Can it be added to a ROM after, or does it need to be built with the ROM
                  It seems i fcked up something :-)
                  I flashed two times csa rom, and zido also, bud it wont boot. I just purple light on box.
                  Tried to go into recovery, but no go.
                  Ofcourse, full erase then flashing rom
                  Edit: Zidoo v5 flashed ok I will try CSA again...
                    OMG, totally screwed that one up
                    Sorry. CSA rom wont work, was tired yesterday when I did this.
                      Well i got L3 WideVine working, but no HDCP so probably no higher levels
                      but it works the same as Wasser and Mo123 roms
                      i've uploaded v6 see main page
                        hi I have a problem I have i68 gigabit and these roms Zidoo not working me bt and wifi
                          And everything else works fine?
                          Does i68 have same hardware as r68? What wifi chip?
                            so I use from the original rom Tronsmart (205L1_ firmware for Orion R68_Gigabit(Updated))and everything works 100 %
                              so I use from the original rom Tronsmart (205L1_ firmware for Orion R68_Gigabit(Updated))and everything works 100 %http://www.tronsmart.com/?p=5133"] [/URL]
                              That's weird, everything works well for me, which version did you flash?
                                1-6 the same problem wifi and bt dont work in Ugoos bt work wifi dont
