I am a Chinese player, English is not good, I have a rk3368 cloudnetgo, this and mk68 RKM the same kernel, ask me to brush your firmware. Thank you
Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
First of all a big thanks to lonix for his efforts in porting the Roms for our STTTTUUUUUUTERINGGG Orion R68 (CRAP) box!
I have been using my old CS968 with little problems .Silly me thinking that a newer more powerfull box would be nice!
This box has been so anoying to me since the day I recieved it due to its major flaws that it sits mostly unused waiting for a properly functioning Rom.
Back to the trusty CS968 in the mean time.
I tried to publish a POOR review on Geekbuying where I had purchased my Orion to warn other potential buyers of the issues. Only to have them not publish my review and instead "Try to FIX the problems" , eventually they offered to repair my device, but I am sure that it is a software issue (Rockchip shit SDK). I do not think it is a very honest or good business practice to disallow negative reviews as it does not really reflect the overall user experience, but makes people think that a mediocre product is in fact good.
Sorry for the rant....
Now to my questions.
Do these Rom's have a unified partion(emulated) format like Wasser's Rom?
I have become a fan of that partion layout due to the fact that the entire usable memory is available for anything(ie no restricions on app. installations due to limited partion size).
If this is not the case, is it possible to make versions of these Roms that use emulated storage?
Thanks.
Originally posted by dillweed View PostI'm running zidoo v3 on 2 of my tronsmart meta with no issues at all.....
it a problem with old 2009 tv with hdmi handsake ( not all tv )
tronsmart solve the problem ( probley the orignal kernel that lonix used on the first rom )
zidoo will solve the problem on the next version rom.
First dude, thanks for your hard work to try and improve our unfortunately disappointing boxes.
I have flashed the Zidoo ROM and having problems with the Ugoos one. I love the ROM, launcher and android TV apps however, I'm still having the same issues with stuttering (YouTube, showbox, kodi etc). Am I the only one still having the same old issues?
Originally posted by Vinc3nzo View PostHi!
Very big problem with KODI (Firmware V3) (test with ISO BLURAY) have problem lip-sync :/
and have message "update to 15.2, actual is 15.2 RC"
Confirme me have same problem?
To install, uninstall current kodi
Unzip to root of a USB stick
Install .apk using USB install app
Reboot to recovery using quickboot
Install librkffplayer using TWRP recovery
Click install change to usb storage and select file to flash
Originally posted by Bazmamfoo View PostFirst dude, thanks for your hard work to try and improve our unfortunately disappointing boxes.
I have flashed the Zidoo ROM and having problems with the Ugoos one. I love the ROM, launcher and android TV apps however, I'm still having the same issues with stuttering (YouTube, showbox, kodi etc). Am I the only one still having the same old issues?Last edited by lonix; 14 January 2016, 07:36.
Originally posted by lonix View Post
Sorry, guys I've decided to discontinue working on the Ugoos rom due to wassers new firmware being 100x better, I will however continue to work on the Zidoo rom.
.. So wassers firmware is compatible with our Tronsmart R68 ?????
Where can I find this firmware to test ?
Installer, waser firmware in R68 Meta (2,16)but still the problem of stuttering and the colors look dull. The intenet is super fast, I think it is the fastest out there.
I'm reading about DRM in boxes android. In Waser Rom (Google Widevine DRM moudlar this in Stage 1, while in Zido firmware does not exist.
This is very important because the higher the level (level-3), we see better quality content, Netflix and Google 4k movies or other apk
Info :This apk :https://play.google.com/store/apps/d...idfung.drminfo
Example: WeTeck have google certificate, buy the level is 1. Is no much, i don't like this box, my transmart R68 Meta is better. (software is trash)
Ionix, is possible level 3 in zidoo firmware? or same level 1. wasser rom?
Thank You
There are currently 1244 users online. 1 members and 1243 guests.
