Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
    Hi Juniors,
    Please go back at the beginning of this topic, and then you'll see everything that is needed to know how to hack the different Rk 3368 models.
    Btw.: many complaint about 9.x ROMs. I'm still running 8.3 on R68 Meta that works fine and stable for more than a year already. "Lifetime Hack" was applied, MAC address is fixed with Flashtool by lonix, CPU clock frequency is set by Kernel Auditor at every bootup.
    Kodi is v16 from Zidoo 1.034 with modified advancedsettings.xml. Screen refresh rate change works, HDMI and Spdif audio passthrough (DTS, DD) works, 5.1 PCM transcoding to DD works. For watching movies by Exodus addon in KODI, what else you need? I read about the latest Amlogic 912, that still is not better on movies.
    Everything you can find in the previous posts of this topic.
    Regards, STZO
      Hopefully someone can shoot me a straight answer, as the search has given me nada. Thinking of grabbing a Beelink i68. Would this rom be compatable without too much fuss, and are the necessary lines of code in the kernel for touchscreen support. Touch support is an absolute must as this is for a car media hub. Any info would be appreciated.
        No touch support in i68.
        Lots of people reported Youtube stuttering and audio problems on this device.
        So better to look at another R3368 device with better support and maybe touch screen support like Geekbox that is open source.
        A guy there also made a car project and turned his device into a car touch screen media player.
          Maybe you do better buying an Amlogic device, e.g. 912. That also suffers from some early diseases, but hopefully, the support will be better. Beelink GT1 looks a massive construction.
          Regards, STZO
            http://forum.geekbox.tv/viewtopic.php?f=15&t=3472
            Thanks for the helpful info. I reached out to the dev and didn't hear anything back as well. Just asked if he had any suggestions or insights. Unfortunate.
              I've been hunting forever in terms of finding new suitable hardware. I seen the GT1, but the risk of no touch support with these great boxes kills me.
              heres my current setup, utilizing a MK908, finless 1.7 on 4.2.1
                Tested all custom roms on tronsmart r68,and i cenot belibe how much lag and stutter this device has .Wotching you tube is very hard with constant stutter.I cen not belive tronsnart is shiping this device with so many bugs.sory for ny bad english
                  Originally posted by mikiaki View Post
                  Tested all custom rons on tronsmart r68,and i cenot belibe how much lag and stutter this device has .Wotching you tube is very hard with constant stutter.I cen not belive tronsnart is shiping this device with so many bugs.sory for ny bad english
                  They discontinued producing tv boxes months ago and even closed their forum where people complained.
                  If you got it recently return it for something else or sell and buy something new again.
                    Tanks for yor answer,whot box to buy for 50 usd ?
                      With ut4 rom tronsmart r68 works perfect.
                        I will try that ROM, normally Ugoos does a good job with its firmwares. By the way, that ROM is Android 6.0
                          Have you got a link?
                            Ugoos Brand UT4 Box - New metal housing 2G+16G Android 5.1 Lollipop Octa-Core RK3368 64 bit Smart TV Box with High Quality Firmware, Dualband 2.4/5Ghz WIFI, Bluetooth 4.0. H.265 Hardware Playback and 4K Output Support.
                            Sent from my U65GT using Tapatalk
                              Hello everyone ^^,
                              I have a beelink i68 (1gb/8gb) with the v9.5 rom. Its works really smoth, but the wifi has a Problem. Its only use 20-30% of my internet connectitivity. Its not a Hardware issue because with v8 i had full Download speed, but the zidoo activc. Popup came every 10 sec. ( of course tried the activ. Fix and reboots, but not work)
                              Tested with speedtest by ookla
                              I hope somebody can help me
                              Br,
                              Skycrow67
                                For the last 7 days I have been trying the UT4 Ugoos firmware (Android 6.0.1). Is it perfect? No, but it is much better that the official Tronsmart firmware. Stuttering isn't in the Ugoos firmware but in return you get mini freezes at the first seconds of the YouTube videos; personally I can live with the mini freezes.
                                Ugoos ROM has a unique partition; no more system partition and data partition (I don't remember about Tronsmart partition, really)
                                Hardware is working very good: WiFi 2.4Ghz/5Ghz, Bluetooth, Ethernet, HDMI port and USB ports (I have not tried the SD card reader or the remote control). Power LED has both lights (blue and red) always on.
                                My experience with the Ugoos firmware is positive and for now I will keep this firmware.
                                Greetings
                                Miguel
