There were actually quite a few files that have been updated, mostly to do with audio.
Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
Originally posted by lonix View Post
I used meld to merge the differences and forgot to delve into the /system/lib folder.
Is the activation problem is preinstall.sh can you? I have a transplant 3229, and now there is the problem of activation, please tell me, thank you!!
Originally posted by thunder k View PostSilly question :
How do you know the 5 ghz does not?
On clicking one of them it will show 2.4Ghz under Frequency and on clicking the other it will show 5Ghz under Frequency.
Originally posted by ontherocks View PostIf you have 5GHz working, you will see two entries for the same SSID in the wireless settings.
Originally posted by jorgitobg View PostNew full firmware 9.4 works very fine for me.... only tested some hours.
Originally posted by mastro7712 View Post
I found the guys here was my problem .... basically was the APP that I used that gave me such problems ... changed APP now everything is ok ... only it remains to integrate the new rev. the Bluetooth and fix network 5GHz !! Now the rest is going great !! Thanks a lot to all developers ...
What is that APP you mention?Regards, STZO
There are currently 1597 users online. 0 members and 1597 guests.
