Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
Zidoo firmware v19 flash with factory tool, update, zidoo firmware 1.34v when finish, other update with 1.36v. Install twrp with Flashify_1.9.2-64.apk(found apkmirror). Put ionix kernel zip inside android partiition and TronZid-ActivationFix-070316. Install with twrp. You have new versiĆ³n firmware (1.36). When ionix finish completed and tested, only update kernel. Easy
I have a Nexbox Z68...had flashed ionix 9.2 w/Z68 kernal...working o.k....then installed the 1.36v over it with z68 kernal...so far so good...ir remote is working..use it only with ZiDoo Kodi and some games...no reboots...the only issue I was having is with Dolphin Browser..no Flashjet in settings...but Browser works fine!Last edited by freakkid; 04-23-2016, 14:24.
Hello Ionix, please help me use your rom on my device. I downloaded the v9rev2 full rom. Flashed it amd waited till it fully loaded up, IR remote not working also BT/WIFI than i flashed my original kernel and resource back but it just stays at the boot logo screen. Please help me run your rom on my device, my original kernel and resource img. Thanks in advance ! https://mega.nz/#!8lQzUZgR!mfe_v4Y39...pG2VS9QIbQ2n9sLast edited by brickmojoccatz; 04-23-2016, 10:26.
Originally posted by brickmojoccatz View PostHello Ionix, please help me use your rom on my device. I downloaded the v9rev2 full rom. Flashed it amd waited till it fully loaded up, IR remote not working also BT/WIFI than i flashed my original kernel and resource back but it just stays at the boot logo screen. Please help me run your rom on my device, my original kernel and resource img. Thanks in advance ! https://mega.nz/#!8lQzUZgR!mfe_v4Y39...pG2VS9QIbQ2n9s
It's an unknown chinese one, im afraid. Leadcool ott tv box. Thanks for the help in advance !
http://www.aliexpress.com/store/prod...577767855.html
Edit: Flashed the v8rev3 full rom, than reflashed the original kernel and resource. Problem now the box wont turn back on with power cable and switch on. Only when i remove the power cable and put the power switch off and connect usb to PC ...Last edited by brickmojoccatz; 04-23-2016, 13:21.
Originally posted by brickmojoccatz View PostIt's an unknown chinese one, im afraid. Leadcool ott tv box. Thanks for the help in advance !
Unfortunately i dont have a stock image rom avaible, ive send a request for one to the company selling it Leadcool. At android settings it said rk3368-box userdebug lmy47v lihaiming.
As for the power, i tried another adapter and the box boots, really bad quality stuff. Thanks for the help i appreciate it.
lonix Hi,
I'd like to ask for an advice with WIFI on your ROM. I'm using Beelink i68G device (with 5g wifi) and it works just fine on original 206 firmware while on your ROM the wifi doesn't work unless the nvram_AP6330.txt is renamed to **6335 when wifi doesn't function in 5G mode.
I was hoping that simple copy of nvram_AP6335.txt from Beelink ROM would do, but it doesn't. Do you have other suggestions how to get 5G work on your ROM?
Thanks!
Thanks!
Kinda happy today the company Leadcool send me a link to the original firmware, it's http://leadcool.net/download/RK3368_...ol_factory.zip. Appreciate your help Ionix, im hoping to run your rom on my box with your help. Cheers
edit. another problem, the device wont turn on anymore, first time it did that i changed adapter and it booted, i could also boot it from usb cable to pc. Now nothing works, tried 3 diffrent adapters, tried connecting to pc ... nothing ... Bricked i presume ..?Last edited by brickmojoccatz; 04-25-2016, 08:08.
Originally posted by lonix View PostI built a kernel for beelink a long time ago, but nobody told me weather it worked out not. https://mega.nz/#!rQZyVCob!_6oSj9Zvw...WgZPc9MnPnqNXA
I managed to get 5G WiFi working by fiddling around with Android Tool and original FW, but that must lose some of your kernel tweaking goodies. I will test your kernel tonight and give you a full report.
I'll try to find the list of your V8 firmware tweaks to test for.
Thanks!
Originally posted by brickmojoccatz View PostKinda happy today the company Leadcool send me a link to the original firmware, it's http://leadcool.net/download/RK3368_...ol_factory.zip. Appreciate your help Ionix, im hoping to run your rom on my box with your help. Cheers
There are currently 2970 users online. 3 members and 2967 guests.
