Glad to represent Android firmwares for Ugoos UT4 based on Android 5.1.1 and Android TV.
The firmware is enabled a lot of features such as Gamepad settings, TvSettings, RkGameControlSettings, multi-window mode, Ugoos Kodi, Ugoos Launcher, Ugoos FileManager and more. We hope that this will significantly improve the performance of devices.
Android TV:
Change log (version 2.0.0) – 12 May 2017:
New in version 2.0.0
- Android 6.0.1.
- Support 64-bit applications.
- 64-bit Google Webview instead of system Webview.
- New Ugoos Update Service.
- Debug Settings (Ugoos Settings -> System).
Change log (version 1.1.4) – 31 October 2016:
New in version 1.1.4
- Added ability to move apps to SD card (More settings -> Apps).
- Enabled BLE peripheral mode.
- Added Android TV remote service.
- Added exfat, ext file systems for SD card.
- Added event for BACK key on RC in recovery menu.
- Fixed Netflix audio sync issue.
- Translation changes (eng,de,ru).
- Fixed no-touch resources problem.
- Fixed OK button on RC.
- Updated Ugoos Kodi (fixed slider, playback bugs) - manual only.
- Increased time for auto retry download OTA package.
- Fixed progress bar for full OTA packages.
How to flash this firmware:
1. If it first time, you need to install drivers use DriverAssitant or manual when connecting device
2. Run AndroidTool.exe
3. Switch to "Upgrade Firmware" tab
4. Press button "Firmware" and select update image (Example: "ut4_1.0.0.img")
5. Connect device to PC via USB OTG port (full guide by connecting you can find in "ugoos_firmware_upgrade_guide")
6. Press "Upgrade" button
Firmware for UT4 (based on Android 6.0.1)
Version |
Download |
v.2.0.0 |
Firmware for UT4 (based on Android 5.1.1)
Firmware for UT4 (based on Android TV)
Version |
Download |
v.1.1.4.tv |
