Official Ugoos firmwares for devices based on rk3368
    Originally posted by milchmann72 View Post
    Hi to all again
    is there already a TWRP Recovery for the UT4 ???
    You can always go to Ugoos's blog to see latest firmware and guides
      Hi Mo / and all others
      Thanks for the Links,i already flashed the 1.1.2 ,first what i did.
      I will flash the Recovery later and report.
      nice Day
      milchmann72
        We released new firmware (v1.1.3).
        Information about release, you can also read in official blog - ugoos.net
        Available OTA updates from v1.1.2.
        Originally posted by Serega Ugoos View Post
        Change log (version 1.1.3) – 9 August 2016:
        New in version 1.1.3
        • GamepadSettings. Now you can easy share profiles. Profiles saving into /sdcard/GamepadSettings.
        • Daydream. Added ability of disabling wake up from motions (mouse, gamepads).
        • Daydream. Renamed sleep timer into additional timer. Added а choice of actions (sleep, hibernation, shutdown) for additional timer.
        • Added masked HDMI setting (Ugoos Settings -> System -> Masked HDMI).
        • TvSettings. Added check input parameters for File server Settings.
        • TvSettings. Added multi window switch.
        • Added ability to enter NTP server (Date & time Settings).
        • Removed Face Search app.
        • Updated GAPPS, YouTube, Chrome. Replaced email and calendar apps on apps from Google. Added Play Games app.
        Fixes:
        • GamepadSettings. Fixed crash toast bug.
        • Daydream. Fixed sleep bug in YouTube and other apps.
        • Fixed bug with audioinput in some apps (Skype, wechat).
        • Improved SystemUpdate app.
        • Fixed crash of keyboard into VPN Settings menu.
        • Cast screen now working (Settings -> Display -> Cast screen).
          Hi Mo & all others
          i flashed it , it works,but first Time i booted to Recovery it ask me if i want to use it in "readmode only" or if i want to install a "modded" Version or something
          like that.Is this normal ???
          nice Day
          milchmann72
          now i have to Update
            To Serega Ugoos
            There are still some bad or not translated parts in System ( German Language ) if you want i can help to translate the wrong or not translated parts for you ??? For me a good translated Rom is a must.
            If i found more bugs i report.
            Have a nice Day
            ​​​​​​​milchmann72
              To Serega Ugoos
              Have a nice Day
              ​​​​​​​milchmann72
              Can you perhaps take screenshots of the menus with the screenshot icon, then write correct translation below it and zip all the files together?
              I will then also send you a list of all the menu names, then you can just translate and mark in red or something what must change, it might be a little different then Ugoos firmware but will help you.
                Hi Mo
                Yes i can.If it helps to make the RK3368 Roms better.
                nice Day
                milchmann72
                  Hi Ugoos Team & all
                  How can i make "increment Update" if the SDCard not mount correct on 1.1.2.
                  I was not able to download full .img from Ugoos Servers down 50-90kbs take near 2 Hours,
                  after that i wanted to unzip,but nothing,file corrupted.More than 400 MB for nothing.Thanks.
                  Only "increment Update" download Speed was normal.
                  So how can i update/flash it ??????????
                  Nothing pops up and says update if i start the Box.
                  Sorry Mo if i can not update i can not start to translate.
                  So it will take much longer to finish.
                  One more Question why on every UT4 Box under the "OCTA CORE" Sticker stands "QUAD CORE", Ugoos Team.
                  I will upload a Picture later,please answer.
                  nice Day
                  milchmann72
                    Hi all
                    i was able to load the "1.1.3 full image" from another Router and flashed it now i can start translating the missing parts.
                    nice Day
                    milchmann72
                    here is the Picture "QUAD CORE"of UT4 Box.
                    http://img5.fotos-hochladen.net/uplo...16081305it2ycn
                      Hi all
                      nice Day
                      milchmann72
                      here  is the Picture "QUAD CORE"  of UT4 Box.
                      There is no attachment, please re-upload.
                          Hi Mo
                          here is the Picture,took the wrong link.Sorry.The Translations take a few days,hope you can wait !!!
                          Mo if possible can you delete this " " it always shown up after saving & posting Threads.
                          I already deleted this "Signs"from the orginal Thread.
                          nice Day
                          milchmann72
                            Hi Mo
                            nice Day
                            milchmann72
                            I think there was a printing mistake because they also have different quad-core tv boxes and it was too difficult to reprint all the boxes and easier to fix with a sticker.
                            Lots of companies use similar methods. It is definitely an octa-core device.
                            I finished all the translations for you.
                            Please correct spelling mistakes, correct word order or use different words if they have a better meaning.
                            Go to different app folders/res/values-de/strings.xml and change what you want.
                            If you want to help with translations in my firmware also, I uploaded HPH_V1.7_translations_DE
                            If you find some translations that are completely wrong, you can fix it if you can.
                              Hi Mo
                              Can not download the UT4/1.1.3 files only blank page opens when i press it.
                              The other file i loaded from PM.
                              Will do my best but takes a while.
                              nice Day
                              milchmann72
                                now this always comes if i press enter.
                                i saw this in one of your comment , does it now happen on your keyboard too or is it a Freaktab Bug ???
                                Hi Mo
                                nice Day
                                milchmann72
                                Here are UT4 1.3 and my firmware translations.
                                See if you can improve it.
                                https://drive.google.com/file/d/0B2J...ew?usp=sharing
                                It looks like attachments are broken and also the strange letters appearing on posts because of an error on freaktab forum.
                                Hope they will fix it.
                                You can try to clear browser cache, logout and re-login, I don't get the strange letters so much anymore.
