Official Ugoos firmwares for devices based on rk3368
    Hi Mo
    Thanks i loaded it and will do my best,but i made my own Translations from 1.1.3 with Screenshots and Hints.
    Upload it if ready for you too,but it will take a few Days together with yours but i think they are identical.
    So i was not the only one with this strange Bug,hope they can fix it.
    have a nice Day
    milchmann72
      Hi Mo & Ugoos Team
      here are the HPH 1.7 Translations , but for me it is better to translate with flashed Rom , so you can see the relation to the Rom.HPH 1.7 is a RK3288 ROM.I can flash it on my UT3 to translate.Better.
      A Hint under Storage , for the SDCard are other words used as for the rest USB Devices.Make it same in German , take the words of the Storage/SDCard part for all Devices.
      MO_FERTIG.zip
      Hope it makes it better , but i really think it is better to translate flashed.
      nice Day
      milchmann72
        HI Serega & all
        I still have Problems to mount SDCards not one mounts correct.I already uploaded a picture with the bug in the new UGOOS Thread.
        It is not possible to install one App always "Parsing Errors" and Folders disappear,after that the "Lost.dir" Folder is full with Files.
        Even erasing the SDCard did not help same Bug as before,same with restoring the Device.
        Can not use my new UT4 because off this,very nice !!! Please fix this Bug.
        nice Day
        milchmann72
          Originally posted by milchmann72 View Post
          HI Serega & all
          nice Day
          milchmann72
          Hi
          Can you try formatting the SD-Card to FAT32 on a PC?
          Please try with my latest firmware if you also have the SD-Card problem.
          HPH NT-V8 ROM V1.6 by mo123 http://www.multcloud.com/share/fecca...b-28f19208f71f (http://www.multcloud.com/share/feccafbc-87f1-46d9-832b-28f19208f71f)
            Hi Ugoos Team & Mo
            Mo you were right after format the SDCard it showed up correctly,but still not possible to install Apps because of "Parsing Error" tried it from my UT3 & T7 Backup SDCard.
            I hope Ugoos will fix this with a Update.
            Mo i try yours and report than.
            nice Day
            milchmann72
              Hi Mo / Ugoos Team & all others
              i flashed your 1.5c not bad first impression,but still bad wrong translations,but i report that you can fix it.The SDCard Bug not happend first test.
              Later more , and are my Translations helpful for next Rom ? , i hope Ugoos use them too.
              nice Day
              michmann72
                can you make this work for ap6330 wifi please ....
                  Hi minixfreak
                  you can try this.
                  Beelink i68 firmware WiFi and Bluetooth fix for AP6330 chipset, BTW Zidoo v7 eliminated all of the stuttering as far as I can tell. Hardware : Beelink i68
                  good luck
                  milchmann72
                    i need 5ghz to work .. 2.4 is so slow
                      Hi minixfreak
                      you can try to flash the kernel and resource.img of your stock or custom Lollipop Rom,that normal helps with Wifi and BT.
                      nice Day
                      gefattern
                        Hey all, I have an EKB368 and today installed UT4 1.1.3 to get a unified partition, which is working well, but when starting I have to keep holding down on the power button for about a minute past the boot or it will turn itself off. Any ideas?
                          Hi Plysha
                          of course you have problem's there must be a difference in resource & kernel.Normal,try flashing resource & kernel from your stock or custom FW,that must help.
                          Report if it works,do you know how to to it ???
                          good Luck
                          gefattern
                            Hi Ugoos Team & all others,
                            here are my Translations for German of Rom 1.1.3 please use them for the next Rom.
                            Germantranslations.zip
                            and here are once more the SDCard Bug Screenshots.
                            please fix it not possible to restore anything even the Lost.dir Folder filled up and Files were gone after mounting on other Device.
                            3g Sticks still have Problems not Network,even the old since KK exist BassBoostBug in Equalizer still exist.
                            Mo of course you can use the translations, too.
                            One more Bug Ugoos on Boot the blue Power Led,flashes weak.With Mo's Rom this not happend,i thing the Power Managment is
                            better adjustes.Please fix this.
                            Of course the translations can be used for RK3288 too.
                            have a nice Day
                            gefattern
                              Hi Plysha
                              good Luck
                              gefattern
                              Thank you gefattern, I think that I use Android tool with a new FW img that I have believe is known to work with ekb368 and checkmark only resource and kernel and then flash as I did for the complete image? Could it be that the flash went awry and I just need to use the same FW img? I guess that I could just reflash and then I would know for myself, just being lazy. I'll keep you posted on the results, though.
                                Hi Plysha
                                i possible first 1.1.3 and than the Rest.Good luck.
                                gefattern
