here are a Report about the Bugs i found.The Device is STOCK and until now i haven't activated Root or installed one App.
1. If i plug a SDcard with Data on it (Fat32) in the Slot it's mounts but only shows 0B/free/0B/used and unmounts after about 30 sec.After Reboot the Card is not able to mount and can not be mounted over
Settings/Storage.Even after wiping the Card ,the System could not mount the Card.Only unplugging and re inserting the Card made it mount ,but still 0B/0B shows up.Controlling the Card on Pc showed that
the Data wasn't wiped.
2. If i plug a SDcard with Data on it (exFat) in the Slot it makes the same ,if it mounts it shows 0B/0B ,even after Reboot no mount.Only after wiping ,the Card showed up correct and it was possible to
unmount and mount again several times.But when i took the Card to Pc ,the Name of the Card and on the Card self ,had strange China Signs and Folders on it.Look the Pictures it was after i wiped the
Card.
1
2
Sorry for the bad Pictures ,but you,can see what i mean.
Now i activate Root and test once more.
1. A SDCard without Data (Fat32) mounts and unmounts without any Problem.With Data same as before no mounting.With (exFat) a empty Card it mounts even after a Reboot not.Only with a
SDcardreader plugged to USB it works for both Format with and without Data.Once or twice the SDCard with Data (Fat32) was shown as empty Card in SDCard Settings.
Now the Read Error Bug : a SDcard with Data can not be opened with the UGOOSFileexplorer it says "ReadError Please check this file is readable or exist !" the same with (exFat).
I found another Translation Error in Gamepad Settings.Look.
if you can see stands under "Gerät" Usb composite Device but twice ,one Time is enough or not ? In German "USB Verbundgerät" the same must be changed in the Pop up Menu.
Same under LANGUAGE & INPUT PYSICAL KEYBOARD ,not tchip_remote_key in German it must "TCHIP Drahtlos-Schlüssel" and as before "USB Verbundgerät" not Usb Composite Device.
It looks like that the EQUALIZER BASSBOOST Bug still exist ,still not possible to change the Bassboost Level.
Now i want to install the SDFix.apk and test once more.
After i insert a Card with Data (Fat32) into the Slot the Card was shown in Storage ,but with wrong value (empty).A Reboot brought back the same 0B/0B Bug as before.
The UGOOSFileexplorer and StorageSettings says still the same (ReadError) if you want to access the Card.
Then i plugged the Card in without Data (exfat) ,the Card not even mounted and could not be mounted over Settings.Same with Data ,even after a Reboot no mount.But no "ReadError"
poped up.Only after wiping the Card i was able to unmount and mount again even after a Reboot the Card was still good.
It is not possible to use the SDCard Slot and that is bad.This is all first i hope that Ugoos can fix it.And what about XPOSED Installer and TWRP Recoverry we all like it.
First that's all and i report if i find more.
nice Day
gefattern
