Official Ugoos firmwares for devices based on rk3368
Hi Serega
First of all not bad,but there are still (German) Translations missing or wrong.I can help the same way as before with Screenshots and txt File Translations.
There is still the same Problem with Ugoos Fileexplorer "Read Error",after installing SDFix it was gone.Device was already rooted.
The SDCard Bug still exist.Empty Cards are shown correct.SDCards with Data not,they show 0.0 used / 0.0 free and they unmount alone.But if i use
a Cardreader on USB Port it works.
If i plug in a USB Device it is only shown as USB 0 / on all 4 Ports USB 0 Device in use.
I opened the platform.xml and could directly see that "sdcard rw" is missing under "WRITE MEDIA STORAGE"
and under "WRITE EXTERNAL STORAGE" media rw is missing.So how could it work correct ????
Please check this.
There is a small TxT Frame Error in Kodi/Settings if you want to change to Expertmode the word over Expert stands a little bit outside the Frame.
The Ugoos Launcher is not bad but not really customizable,bad translated to German,double and stupid named catagories.
Not possible to use Icons without Text. Ugoosfileexplorer only possible to delete File by File.
Settings Tv are not scrollable with mouse,and why not only using Stock Setting always double work to use Settings,i prefer StockSettings.
There is a seperate Android Tv 1.1.4.img Rom.
So that is the first Impression nice Day
gefattern
Please check this.
gefattern
We used your German translations. Not all strings should be translated (for example, names of gamepad buttons) and not all strings can be translated. We reconstructed the code for some items to make their localization. You can send strings for untranslated items and we will add them if it possible.
Can you tell more details about Ugoos Fileexplorer "Read Error" ?
Are you tried insert sd card without root and SDFix? What file system you use? Are you tried other file systems?
USB Devices shown as USB_DISK0, USB_DISK1, ..., USB_DISK10 depending on the order of connection to the device, regardless of the port. You can connect usb hub and it will work well.
We will think about "platform.xml". You can use ES File Explorer for write operations on sd card.
About Ugoos Launcher, wait next updates in Google Play Store. We will add new features and bug fixes.
In Settings Tv you can use left button for scrolling with mouse. Also you can use https://play.google.com/store/apps/d....quickshortcut for creating shortcut of StockSettings.
Android TV firmware is designed for use with remote controller. But you can use mouse too.
Nice Day.
Hi Serega
I later upload Screenshots to show what i mean.(Translations)
I use EMTEC Sdcards 16 GB Class10 for my Devices.
First i flash the FW new and will then report over Error and Bugs.
Small Hint the "ReadError" Bug already was on 1.1.3.
I have this UT4 Box but cannot use it.Very nice 80 € for a until now not nice usable Box.
You hear and see later more of this good Firmware work.
gefattern
Nr.8
first "hide tile background" in German "Kacheln deaktivieren"
and "benutzen system hintergrund" must be "Systemhintergrund benutzen"
don't use "Rahmen" in the Launchersettings better is "Fenster"
change "SCREENSAVER" to German "Bildschirmschoner"
and "THEME" to "Farbwahl"
and please delete the Categories "Rahmen"(no Name for a Categorie) and "Andere" not needed because of "Alle"
"Tools" must be "Werkzeuge"
gefatternLast edited by gefattern; 04 November 2016, 00:46.
There are currently 2084 users online. 1 members and 2083 guests.
