Official Ugoos firmwares for devices based on rk3368
    Originally posted by shivattaque View Post
    Thank you for having answered this fast, I will test for the root, because I will be able to change the files wifi and Bluetooth. For the sound problem it takes more testing to be sure.
    If not, an idea for the light.
    The light is from the kernel and resource.img
    Try to use RKMC Kodi.
      After changing files with Mixplorer the Bluetooth works.
      I have not tried the wifi because I use rj45.
        The kodi ugoos works not bad but i will also test Rkmc to see if my problem jumping image and sound came from ionix 9.5.
        I've also seen a problem that persists in YouTube, The sound and image jump at the beginning.
          Hi all,
          my UT4 runs hot while Gaming i want to add a beter Fan , is the Fan of the UT4 soldered or does it use a Plug to connect to PCB ???
          I know there are Pictures of the PCB but where ??? and what Voltage is needed ???
          Until now my Kodi runs good no drops !!! Youtube i must test first to see what is going on.
          nice Day
          gefattern
            I specify that I am in HDMI passthrough.
              Originally posted by [email protected] View Post
              Hi Everyone,
              I Flashed v.1.1.4.tv FW to my NewBox Z68 and everything worked fine, but can not add more shortcut to screen.
              Does anyone know how?
              Android TV Launcher displays only those applications that have special flags for android tv.
              To display other applications, you can use https://play.google.com/store/apps/details?id=eu.chainfire.tv.sideloadlauncher&hl or something else
                Hi Serega ,
                what Clockspeed use the GPU of the UT4 ??? and can it be overclocked , because i have hicks & short hangs while gaming DEATH TRIGGER2.
                That's not happen with UT3 and DT2.
                I really thought the newer build Device has better Specs , what becomes the maybe UT5 for a GPU ???
                And where i can find Info's about the Fan and his Plug of UT4 (Pictures , FanSpecs) ???
                75 °C and higher are not good.My UT3 never goes higher 55 °C.
                please answer
                nice Day
                gefattern
                  The sound and image still blocks with FTMC B13.
                  Everything works very well for 20 to 30 mn and it blocks half a second and it leaves again in the best,
                  if not more sound and I have to go out or cut the passthrough to restart.
                  I do not understand some say it works well.
                  I realize that on this box the problems come mainly from sound.
                  (youtube, radio, Kodi...)
                    Hi Serega ,
                    please answer
                    nice Day
                    gefattern
                    600 MHz. UT3 has a different GPU chip.
                    75 °C for CPU is normal. UT3's CPU can be heated up to 90-100 °C.
                      Thank you for your time.
                      Khiem
                        Hi Serega and Team ,
                        is it possible to take the Fan of from the Motherboard ???
                        nice Day
                        gefattern
                          I made new Marshmallow firmware for RK3368.
                          It should run great on the UT4.
                          I will need some help to add the UT4 fan to work still.
                          If someone wants to test it, please leave feedback in the thread link, so Ugoos related news can still stay here to not confuse users.
                          New Superspeed MM ROM v1.5 released:) - Super fast - Onscreen keyboard improvements 1. Fixed keyboard to work with IR remote 2. Disabled annoying key clicking
                            Anyone that can identify this RTC battery or it's driver perhaps, the yellow part of UT4?
                              We released new firmware (v2.0.0), based on Android 6.0.1.
                              Information about release, you can also read in official blog - ugoos.net
                              OTA updates will be available later.
                              Change log (version 2.0.0) – 12 May 2017:
                              New in version 2.0.0
                              • Android 6.0.1.
                              • Support 64-bit applications.
                              • 64-bit Google Webview instead of system Webview.
                              • New Ugoos Update Service.
                              • Debug Settings (Ugoos Settings -> System).
                                Great work.
