Official Ugoos firmwares for devices based on rk3368
Still having the problem with the power on not sticking, but I now have a semi solution that works, but not always. The power going to the unit has to have a back up with power going through the OTG for the system to maintain the on status. Anyone have any ideas? Also, I apparently don't know how to install the kernel without installing the complete firmware, that knowledge could help. Thanks again!
Realized that unpacking went to the wrong directory for Android Tool, after putting "resources" in the appropriate directory I was able to update only resources from old firmware. All works now, fantastic, thank you! ugoos firmware puts the old firmware to shame. Having some issues with one app's sound, not sure if I'll change kernel too. If I do, I'll keep you informed. Thank you again!
Hi Plysha
if you use Androidtool for flashing press "Advanced Function"than under Firmware the ... button,load your custom EKB368 Rom .img File to Tool and press "unpack".Wait till ready,go to Androidtool Folder,open
Output Folder open Android Folder open Image Folder,tada there are kernel & resource of your EKB Rom.Close Androidtool,open again,always as Admin,press"Download Image" uncheck all except kernel & resource,press on the end of the kernel line the small box,select kernel from Output Folder,same with resource.Connect Device and press Run.Thats it.
hope it helps
gefattern
hope it helps
gefattern
Hello all.
please fix it not possible to restore anything even the Lost.dir Folder filled up and Files were gone after mounting on other Device.
gefattern
One more Bug Ugoos on Boot the blue Power Led,flashes weak.With Mo's Rom this not happend,i thing the Power Managment is
better adjustes.Please fix this.
gefattern
gefattern, can you think another name for "Autoframerate" setting? Because "Bildwiederholungsfrequenz" too long and it looks not good.
Also we fixed the Netflix problem and include it in the next release.
Thanks to all.
Hi Serega & all others
I use EMTEC SDCards 16GB and one INTENSO.
Yes i can make a log,because of the weak flashing light on boot,can it be change to use the "User Settings". ???
The Best is you change it to "Wiederholungsfrequenz"because the title"Bildschirm"already says what kind of Frequenz it is,
or you can take "Bildwiederholungsrate"both are good.
Hope it helps upload the /UT4SDCardlog\ later.Ask if there is something unclear with Translations.
nice Day
gefattern
Hi Serega
here is the logfile.I mounted/unmounted while the Log runs 5-6 times,that the Bug really stands written in the Log.
I wanted to copy the Log from internal to SDCard,but System says"no write permissions",so i had to send it with BT to my UT3,to upload.
The SDCard was only shown correct in the Slot after i deleted the Card and with a SDCard Reader plugged in.
Can you please fix the "could not find memtrack module"Bug it exist since the first Rom,even on RK3188 boards.
Thats all for first
nice Day
gefattern
Guest
Hello.
Please, can you tell me, how to put this firmware to my tv box (Z4 TV Box 2.4G / 5G Dual Band WiFi 64Bit CPU RK3368 Octa-core Android 5.1 2GB RAM 16GB ROM Bluetooth 4.0) without problems?
I did it one time, but when I took out the cable from pc, the box turn off. Anf the only way to keep on the box, is to hold the button, otherwise the box closing.
I did something wrong or this firmware not much with my device?
Is any other firmware for that box out there? I have this ( http://chinagadgetsreviews.blogspot....op-511_21.html) now on it, but I have problems with kodi and the videos...
Thank you.
We released new firmware (v1.1.4).
Information about release, you can also read in official blog - http://ugoos.net/blog/ugoos-ut4-upda..._tv-ugoos_kodi
Available OTA updates from v1.1.3.
Change log (version 1.1.4) – 31 October 2016:
New in version 1.1.4- Added ability to move apps to SD card (More settings -> Apps).
- Enabled BLE peripheral mode.
- Added Android TV remote service.
- Added exfat, ext file systems for SD card.
- Added event for BACK key on RC in recovery menu.
- Fixed Netflix audio sync issue.
- Translation changes (eng,de,ru).
- Fixed no-touch resources problem.
- Fixed OK button on RC.
- Updated Ugoos Kodi (fixed slider, playback bugs) - manual only.
- Increased time for auto retry download OTA package.
- Fixed progress bar for full OTA packages.
There are currently 2967 users online. 0 members and 2967 guests.
