T428 Study and Research on Experimental Firmwares
Originally posted by Finless View PostIt is in the ROM not the kernel but is a compiled LIB file. I have YET to figure out how to make that work when using a tablet ROM and trust me I have spent a bit of time on it.
Bob.
The ROM works just fine for me, nice and clean, only 'Trebuchet settings' sometimes has force clossing.
Originally posted by strauzo View PostWELL WELL WELL
scaling option are another chinese invention that ruine all. are about 6 months I'm writing these Chinese rom ruin everything. but I write without that nobody reads ?
ALL CHINESE ANDROID FIRMWARE IS NOT STANDARD ANDROID. how can I be able to make you understand this ?
when in doubt take a good device (like samsung,htc,sony etc.) and make comparisons
The rom from tablet rk3188 are not excellent but at least respect some android standards that the stock rom for hdmi sticks don't respect in any way.
I don´t understand what you mean by saying that chinese roms ruin everything. Without those roms these sticks wouldn´t even ship. You are holding too much of a grudge against rockchip and going on quite the crusade about them fixing the problem. I will say this: Rockchip makes the chip, not the android stick. Perhaps this problem could have something to do with the closed-source mali drivers? Or somebody´s bad implementation of the kernel source, building kernels for devices and editing original source files without having all the information necessary to properly do so? There are other potential causes for this problem is all I´m getting at.
Anyway good luck with your gripe to rockchip. You originally told us you´d release the fix to the public when you got the answer to one question. Well, you got that answer. Now you need something else. When will it end?
My seventeen cents.If my work benefits you and you want to help out the cause, feel free to
http://www.hoaby.com/android/donate.gif
BobIf my work benefits you and you want to help out the cause, feel free to
Nexus stable with the included kernel works great on my cx919. Its fast, video performance is good, Netflix and xbmc work. Its just that the picture is too big for my TV screen and gets cut off quite a bit along the edges. The setting on my TV to change the zoom etc seems to be disabled as well even though I can change the TV setting on other HDmi devices like my cable box. Any suggestions to make the picture fit better on screen?
Guest
I do not have nothing against the right mouse button mapped as back button.
But the android source code modified to do that is completly wrong.
The chinese code added, ruine the input managment system of android and you can have serious problems with external input devices like mouse, mouse+keyboard combo, gamepad, controllers
Infact the chinese code added, reinterprets events also of other devices by changing the normal operation compared to the standards imposed by google for external devices.
In essence, this change adds a feature, but it does not take into account the hundred other things that ruin.
You can have problems also in many games whit controller support. This bad change, it can also re-interpret the commands of your hardware controller.
If the Chinese want to disrupt the normal operation of Android, and you are happy with these changes, there are no problems. But at least rename this new operating system to "China OS" and not Android.
p.s.
Also the central button of DroidMote is affected by this bad changes to the Android source code.
I found this on my own without help from anyone, and that is why I do not want to help the Chinese with my work (or other developers that know very well this problem). Much work to solve the problems caused by them and that is not present in the original android.
A serious developer, when adding a feature, ensure first that this new feature does not ruin a hundred other things
When RockChip will start to produce standard android rom for android hdmi sticks, I'll be happy.
Many developers of applications for Android are not happy with the Chinese rom, because they are not compatible with the Google API, my voice is the voice of these developers.
Originally posted by strauzo View PostPlease test first and tomorrow i share all. I am very very tired, I'm working from seven days 24/24
this kernel is for t428 and i tested it with the Nexus rom in the first post.
but the solution is for all rk3188 devices. and it is very very simple.
Just saying.....If my work benefits you and you want to help out the cause, feel free to
Guest
Originally posted by hoabycsr View PostJust saying.....
But it seems that the problem is me and not the one who sold you a badly behaving device.
Complain with Rockchip if you want something, not with me.
I have to work to resolve the incompetence of others. the world does not work that way ', those who make mistakes must pay publicly.
And Rockchip produce only FAKE CHINESE ANDROID NOT STANDARD
The video problem is only a specific problem, the serious problems are others, not standard chinese rom in wich many apps from google paly are incompatible.
I want the Android hdmi sticks FREE from this crap.
1) remove the bad input managment system part or correct it.
2) remove rkremote from the source code of android (an uninstallable app can be good)
3) remove the bad hdmi settings from the source code that ruine many things
4) make standard systemui
5) correct ehomemediacenter that create many wifi problems and make crazy some routers.
in this way we can start talking.Last edited by Guest; 23 July 2013, 10:05.
Originally posted by strauzo View PostRead the post above and you understand. i don't want help those who produce FAKE ANDROID.
in this way we can start talking.If my work benefits you and you want to help out the cause, feel free to
If I´m complaining at all, it´s because you specifically said you were going to do something, numerous times... and didn´t. I´m not generally on here complaining.. Rather I´m on here trying to help find solutions to problems.
And about the ¨those who make mistakes must pay publicly¨ I mean... nice. really. Because everyone else is perfect.If my work benefits you and you want to help out the cause, feel free to
Originally posted by strauzo View Postif you read my post, you understand that all hdmi output should work in this way. also the rk3188 and rk3066 should work in this standard way. But don't forget we have chinese devices.
You don't need 1080p kernel, 720p is the optimal solution for android UI and the videos work in different way, like what is described by you with tablet. and with all android devices.
now I understand why many people ask the kernel 1080p !
When watching a 1080p movie, with this 720p rom, the tv reports a 720p input, always. Image quality is very good, but don't have any evidence that I'm watching 1080p content.
I'm getting tired of this endless China bashing...
Originally posted by hoabycsr View PostIf I´m complaining at all, it´s because you specifically said you were going to do something, numerous times... and didn´t. I´m not generally on here complaining.. Rather I´m on here trying to help find solutions to problems.
Forget your perfect offering
There is a crack in everything
That's how the light gets in
I'm a software developer by profession. I've abandoned the idea of perfect solutions long ago. Building software is always a tradeoff between things like budget, time to market, etc. The truth is that not every developer is a high IQ genius and not every company has the money to hire such developers or are bound by time to market in order to keep up with competitors. So in the end software is bound to be flawed / full of compromises in some way or another.
The question is just: is it acceptable enough for me to do what I want to do. All of strauzo's work till now has been absolutely useless to me. The BT keyboard support is broken and, what's most important to me, webcam support doesn't work either. Both of these work on the latest Tronsmart stock firmware. The only advantage of strauzo's rom to me is smooth video, but that won't make up for loosing skype with webcam. Sure, it might be "free of Chinese software" but that doesn't buy me anything at all. Everybody has different requirements.
Technology like this ages very quickly. You can spend years to perfect all the software on it, but by the time you finish the hardware will be obsolete. So what's the use?
I thought the whole idea of a community like this is so people can join forces to more quickly come to an acceptable solution which makes the hardware usable for as many people as possible (smooth video, BT, webcam, etc), and to bring these solutions to as many devices/brands as possible. No one person can do this alone. Not sharing a solution (or workaround, whatever you want to call it) you've found makes having a community rather pointless.
Yes, I'm disappointed with rockchip. But most of all: I'm disappointed with the community.
I bought a RK3188 not because of rockchip but because it seemed to have the most active community. I guess I was wrong. Maybe I should just stick to running Linux on the RK3188, at least the folks like alok, galland, etc are willing to share and work together as a community.
I started a new thread: How to get rid of our RK3188 device.. aka.. is there life after rockchip?
Originally posted by phjanderson View PostI'm getting tired of this endless China bashing...
...Technology like this ages very quickly. You can spend years to perfect all the software on it, but by the time you finish the hardware will be obsolete. So what's the use?
Yes, I'm disappointed with rockchip. But most of all: I'm disappointed with the commu...T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
There are currently 3397 users online. 2 members and 3395 guests.
