T428 Study and Research on Experimental Firmwares
    strauzo con quale programa posso unire tutti i file di un custom rom ad un unico file come quello della tronsmart, il update.img che ha tutti i componenti in un unico file. questo mi serve perche non posso conettere il t428 al pc. posso mettere il rom solo tramite la sd card. grazie
    Sent from my T428 using Tapatalk 4 Beta
    FIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
    https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
    My Plexi MK802IV mod
    http://www.freaktab.com/showthread.p...xi-MK802IV-mod
      sorry, to meet all write in English.
      i'm uploading a new rom for that reason I have not kept my promise to you. sorry.
      you can use wendal tool. there are many guide in this forum and in other forum. i have only a suggestion for this rk3188. you need also the backup image that you can get also from another rom when you decompress it with the same wendal tool.
        Re: T428 Study and Research on Experimental Firmwares
        thx, i just packed an update file with the wendal tool and i used your rom components. ill copy it to the sd card and flash it. i didnt change the recovery img. i left the original one from the stock rom. is it ok or it is needed to have your recovery.img
          Originally posted by Ercan View Post
          Maybe Small Bug:
          • Switching between recent apps works good in multi window mode, but does not work in normal mode
          Small request: Increase Display timeout, to never sleep?
          Thx.
          In developer options, there is a checkbox "Stay Awake" . If you use this, your device never sleep.
            strauzo i just started flashing the rom but screen turned off and the device is a dead brick now. dont know what to do. any ideas
              Originally posted by darrellr View Post
              i have just seen this official ROM released which claims to fix the BT airMouse problem. http://blog.geekbuying.com/index.php...box/measy-u4b/
              there is a rooted / de-chinesed version here http://www.arctablet.com/blog/forum/...ware-20130718/
              I've just tested this and .... IT WORKS!
              Bluetooth Airmouse works fine, Wireless good too. As the U4B and Tronsmart T428 are identical, as far as I can tell, this should be good for the T428 too.
              What is doesn't have is the ability to read exFAT which other ROMs do. Can this be added simply or will it require a developer to intervene?
              Donate to Finless
                Can anyone confirm that this works on t428.??
                Sent from my GT-I9300 using Tapatalk 4 Beta
                  why you can't use pc to flash rom ?
                  when i finish and upload new version i can made an update.img of the last rom.
                  now i think you can use only a pc to flash rom.
                    I try it but it doesn't work for me, the stick only show android bot at boot.
                    T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
                      Nexus SDK 2 Multi-Windows v1.1
                      solved various bugs:
                      now init.d script work automatically
                      you can mount external hd
                      recover from standby work well
                      improve responsiveness
                        Well the usb otg port is broken so i think my the device now is a ddamn sitting duck. Nice really, device gone from arriving to broken in 3 dayys. I must have set some kind of record
                        Sent from my GT-S7562 using Tapatalk 4 Beta
                          Strange. I got the 'bot but with commands visible as the cache was cleared etc. Took 3 minutes or so to boot. There is a previous thread saying that it is possible to use U4B ROMs http://www.freaktab.com/showthread.p...well-(-CLONE-)
                          Perhaps it is the format that is the problem? Is there any way to convert an update.img file into its constituent .img files? Or to 'dump' them from my stick? I'm happy to follow instructions to get these files for others.
                          Donate to Finless
                            Is it possible to compile and add exFAT support from the nofuse developers?
                            Android ARM Linux non-fuse read/write kernel driver for exFat and VFat Android file systems - dorimanx/exfat-nofuse
                            Donate to Finless
                              https://github.com/rxrz/exfat-nofuse
                              Yes it is possible, if you have some experience compiling in linux and using any rk3188 kernel source.
                              leolas
                              My devices:
                              Gearbest.com)
                                leolas
                                I would appreciate anyone taking the time to compile the library using the appropriate sources
                                Donate to Finless
