T428 Study and Research on Experimental Firmwares
    Originally posted by clement View Post
    How do you do this test ?
    I installed this app:
      torrent
      I need some help.
      utorrent and atorrent just do not work.
      They do not see any Peers and Seeds both say Peers 0 and Seeds 0.
      I can browse torrents, see that there is a lot of seeds but when the torrent client does not see them.
      Do you have any idea what can be wrong the v1 ROM worked OK.....
      Thank You for your help
        build.prop
        Another help request:
        How do you activate the build.prop changes?
          Re: T428 Study and Research on Experimental Firmwares
          Reboot. Please don't post same question multiple times.
          Signature? Signature!
            OK, sorry
              recent apps
              Originally posted by strauzo View Post
              for recent app, if in the settings you enable multi-windows you solve.
              if you want solve also without multi-windows active, edit the build.prop and set voiceicon=true
              but if you set voiceicon=true (enable also volume icon on status bar), you can't enable well the multi-windwows icon from settings.
              i think this is a little bug of the original tablet rom.
              on t428 i don't have rotation problem. but after you put the rom in landscape, you can use also the top right bar setting to lock screen and disable autorotation. click enable and after disable autorotation.
              voiceicon=true does not solved recent apps problem, still can not switch recent apps, just from home screen ...
                torrent
                I need some help.
                OK, I figured it..... I got banned from the torrent site ...
                  Gotta keep that ratio just above 1. Less means you're a bad citizen. More means your stealing someone's opportunity to get their ratio up.
                    home screen ...
                    Enable multi-windows and it works. I'm using a keyboard/touchpad combo (Logitech K400) and experience no ill effects from the multi-windows functionality. If anything, having enabled it has made the whole GUI more responsive.
                    NVidia Shield TV 2015 16 GB || Stock
                    NVidia Shield TV 2017 16 GB || Stock
                    Buy me a beer?
                      multi windows
                      OK, but what is exactly this multi-window ? or where can I find some user guide for it,
                      I am using the same K400,
                        Strauzo , any chance that you can port the Nexus rom to the ug007b , mk802IV ,
                        cozyswan s400 (they all share the same specs)
                        The current Nexus rom doesn't boot on ug007b device and gives a blank screen.
                          Try ,first,"erase IDB"(two times) in RKAndroidTool and then install ROM . It works for me!
                            Audio patch for switch between audio output
                            you can switch between devices also with the app SoundAbout
                            i tested this patch with my HP usb headphones + mic (all ok)
                            test this patch and if all is ok, we can add it to the next version of nexus multi-windows
                            FYI you sometimes have to disconnect and reconnect the usb sound card after a reboot before it works - I'm away for a week and will look into it when I'm back... unless Strauzo figures it out first that is
                              first , thanks for the tip ,
                              i always erase the idb before flashing , although erasing two times
                              is the same as one time i tried erasing two times but it didnt work
                              i still get blank screen
                              do you have old ug007 like me ?
                                AnTuTu scores:
                                - Finless CX-919 1.4 with phjanderson's 1080p kernel: 12975
                                - Finless T428 1.5A: 14525
                                - Nexus v1: 15140
                                - Nexus Multi-Window v1.1 with MW enabled: 15878
                                All in locked landscape mode and 1080p output resolution. Governor: ondemand, i/o scheduler: noop
                                Buy me a beer?
