AnTuTu shows 20,005 - kernel appears to be 1.6 GHz/600 MHz
T428 Study and Research on Experimental Firmwares
Originally posted by strauzo View Post
AnTuTu shows 20,005 - kernel appears to be 1.6 GHz/600 MHzMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Guest
Originally posted by darrellr View PostWorks fine, thanks! BT + 2.4/5 Wifi all working
Re: T428 Study and Research on Experimental Firmwares
Originally posted by strauzo View PostThe kernel is new kernel and was compiled by me. This rom is very very fast and for the first time i can also play many 1080p videos in the last version of XBMC. I not know if is the new rom (better) or xbmc was updated.
Xbmc is constantly updated, many changes for android are committed each nightly.
Signature? Signature!
I'm getting compile errors
Using my ipad so apols for any stupid ios spelling 'corrections'Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
I can confirm that XBMC 13 nightly works brilliantly on1080p material.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
What do i use to extract system img from the update.img?
Originally posted by strauzo View PostKernel.img 1280x720 + boot.img for T428 4.4.2
<DELETED>
get the system.img from this rom http://blog.geekbuying.com/index.php.../#.UsXI-4Uad_U
and swap my kernel and boot img to have the same rom of the mk908 but with right kernel and boot
for root this rom:
download and install this tool http://www.kingoapp.com/
start the t428
start moborobo
moborobo must recognize the t428
start Kingo android root
click on remove root
click on root again
install / update supersu when android 4.4.2 is running on your t428
p.s.
sorry but i not have time to upload also the system.img
Guest
Originally posted by strix View PostWhat do i use to extract system img from the update.img?
You can use also others system.img 4.4.2 for mk908 already rooted and with build.prop modified
Otherwise to root read my post.
I've managed to get the KK kernel sources to compile for the AP6330 and changed a few things.
When I put together an update.img all worked but the root was 'lost' so I guess I've got even more to learn!Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Rooting kitkat is totally different than 4.2.2!
SU must now run as a daemon.
Originally posted by Finless View PostRooting kitkat is totally different than 4.2.2!
So I took the kasty rooted mk908 (ap6210) kitkat ROM (update.img), unpacked, replaced kernel and boot and repacked.
All flashed fine but Root no longer worked. What should I have done differently? Something in the boot.img?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
@strauzo
How did you create the kernel? I have downloaded the MK908 KitKat sources and compiled without amendment of the .config which should have created an AP6210 KK kernel.
I get a successful compile but the kernel will not boot, nor will any of the AP6330 variants I've built (all compiling without (fatal) error).
Can you let me know your approach/share you makefile/.config?Last edited by d33; 04 January 2014, 17:45.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Guest
Guest
Someone know how to enable the internal usb hub of the minix x7 inside this new kernel source ?
Originally posted by strauzo View PostThe default .config of mk908 ii changed only ap6210 to ap6330
I installed Ubuntu 13.10 32-bit into a VM, copied the sources, downloaded the requisite libraries, found a set of pre-built toolchains, set two environment variables (ARCH/CROSS_COMPILE), changed the permissions on mkkrnlimg and executed "make clean" and built the kernel with "make kernel.img"
The only frig I did was to move a couple of includes for the net ipv4 module that were ambiguously named.
Anything obvious I've got wrong?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 1988 users online. 1 members and 1987 guests.
