T428 Study and Research on Experimental Firmwares
    Originally posted by strauzo View Post
    Someone know how to enable the internal usb hub of the minix x7 inside this new kernel source ?
    Minix released sources I think, so maybe worth a look through.
    PHJAnderson has them stored in Git (https://github.com/phjanderson/Kernel-3188-X7). Possibly something in board-rk3188-box.c (used instead of board-rk3188-sdk.c)
    Donate to Finless
      ### Minix NEO X7 configuration
      CONFIG_WIRELESS_EXT=y
      CONFIG_WEXT_PRIV=y
      CONFIG_WLAN_80211=y
      # CONFIG_WIFI_NONE is not set
      # CONFIG_BCM4329 is not set
      # CONFIG_BCM4319 is not set
      # CONFIG_RDA5990 is not set
      # CONFIG_MV8686 is not set
      # CONFIG_RTL8189ES is not set
      # CONFIG_MT5931 is not set
      # CONFIG_MT5931_MT6622 is not set
      # CONFIG_AR6003 is not set
      # CONFIG_RTL8723AS is not set
      CONFIG_RKWIFI=y
      CONFIG_RK_CFG80211=y
      # CONFIG_BCM4330 is not set
      # CONFIG_RK903 is not set
      # CONFIG_RK901 is not set
      # CONFIG_AP6181 is not set
      # CONFIG_AP6210 is not set
      CONFIG_AP6330=y
      # CONFIG_AP6476 is not set
      # CONFIG_AP6493 is not set
      # CONFIG_GB86302I is not set
      CONFIG_USB_RTL8152=y
      CONFIG_SND_RK29_SOC_I2S=y
      CONFIG_SND_RK29_SOC_I2S_2CH=y
      CONFIG_SND_ROCKCHIP_SPDIF=y
      # CONFIG_SND_DMA_EVENT_DYNAMIC is not set
      CONFIG_SND_DMA_EVENT_STATIC=y
      CONFIG_SND_RK_SOC_SPDIF=y
      CONFIG_SND_RK29_SOC_RT5616=y
      CONFIG_SND_SOC_SPDIF=y
      CONFIG_SND_SOC_RT5616=y
      CONFIG_SND_RK29_CODEC_SOC_SLAVE=y
      + base config
      Donate to Finless
        CONFIG_WEXT_PRIV=y
        CONFIG_WLAN_80211=y
        CONFIG_RKWIFI=y
        CONFIG_AP6330=y
        + base config
        The kernel is different and was changed. All old stuff can't be used. Already tested this partial config + the new one from new source and i made also a comparision with the last original minix source code. No work.
        I think that for this reason minix speak not well of this kernel, because some hw component are not compatible by default. fortunately on the T428 android 4.4.2 FLY. (Work very very well, the best performances)
        The new source code of the kernel is better than the old one (100 times, specially on the graphics part)
        Is old for android 4.4.2 but is very fast on graphics stuffs.
        I will study next week to see what i can do with my minix x7.
        On minix x mini only one usb work.......with another experimental kernel.
          The kernel is different and was changed. All old stuff can't bd used. Already tested this config and i made also a comparision with the last original minix source code. No work.
          Ah Shame.
          Donate to Finless
            I have been stating many times all over the forum here in the last 2 days that kernel 3.0.36+ for kitkat (4.4.2) was not the same as kernel 3.0.36+ for JellyBean 4.2.2!
            Major changes have been done.
            I agree with Strauzo that it is for the better
              FINALLY THE COMPLETE SOURCE CODE FOR RK3188
              https://github.com/aloksinha2001/Linux3188
              So now can we get androd 4.4?
                Hi Bob.
                Happy new year.
                If you want you can make a beta firmware 4.4.2 with my kernel for T428. (for all users) Is not a joke i'm really impressed how it work well. I tested also the ART runtime and XBMC (last gotham build) work wonderful also on 1080p materials.
                I think that all must try this new experience on the T428 also standard users.
                Finally Rockchip is doing a great job, if things continue this way I will become the first supporter of its products.
                The Experience teaches, and also all my bad words on Rockchip have served to these excellent improvements.
                  Hi Bob.
                  Happy new year.
                  I will work on it this week. Its been a while since I did a t428 ROM.
                    Your 4.4.2 mk908 ii rom with this kernel. Nothing special for now. But very very good result on t428.
                      Is your kernel 1080 or 720?
                        It's 720 (-menubar)
                        Donate to Finless
                          Yes 720p but i want to clarify that this is not my kernel.
                          This is the new kernel of Rockchip that all can found in the new sdk 4.4.2
                          I only compiled it with ap6330 wifi module, i read all the many differences, and i can confirm that this is a better kernel.
                          With this kernel and the mk908 ii system.img 4.4.2 the T428 is a straordinary new product.
                          I'm only sharing my experience. Nothing special.
                          I'm also happy because the new 4.4.2 firmware is close to aosp and not many modifications to original source code of android are inside. Also for this reason the firmware is very very FAST.
                            Can you share the resolution tables and code that sets resolution?
                            The tronsmart kernels are different and the way I patched 1080 doesn't work on these. l would have to go through the painful process of decompiling the kernel to find where to patch. Some tips on how this changed would make it easier for me to find where to patch.
                              The source code is inside the kernel folder of the sdk 4.4.2 for mk908 ii shared by cnx software.
                              I tested also with a kernel not compiled by me the resolution 1920x1200. (The previous 4.4.2 experiment post by me, from pipo tablet).
                              The next seven days i'm out, when return I try to compile a version in 1080p to see how it goes.
                              For this reason i suggest to you, assemble a dedicated rom for T428 users that not know how to merge part of the mk908 and the kernel already compiled by me. In this way all can understand what improvments there are in the new kernel and in the new android 4.4.2 firmware. (The real and big improvements are in the kernel)
                              I'm sharing only my study for now.
                              To do what you want you need a compiled 1080p kernel to make a diff of the two objectdump. I suggest to compile, is better than patch binary. The resolution can be changed in different way respect to the previous kernel in the menuconfig. (Is not immediatly intuitive as in the previous one, but should be possible also if i not tested it for now)
                              In recent experiments, I was trying to understand how to add in the new kernel the usb hub of minix x7. Wothout success for now. (For this reason i not focalized my attention on the 1080p resolution)
                                Strauzo, if you can suggest what error I'm making in my attempt to compile source then I can try a few options whilst you are away
                                I'm currently using a 64bit VM and can compile the source code without modification. However the kernel produced is not binary identical with the one produced and doesn't boot
                                For clarity these are my build steps:
                                • Installed Ubuntu 13.10 amd64
                                • Got all the required libraries and toolchain
                                  • sudo apt-get install git-core gnupg flex bison gperf libsdl-dev libesd0-dev libwxgtk2.8-dev build-essential zip curl libncurses5-dev zlib1g-dev gcc-multilib g++-multilib sharutils lzop gcc-arm-linux-gnueabi
                                • downloaded the tarball of MK908 (and MK908 II) kernel sources to ~\android\kernel
                                • renamed the suppiled kernel to kernel.img.orig
                                • ran "make clean"
                                • ran "make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- kernel.img
                                I get successful compile and kernel creation. However, if I do a binary compare (cmp -l kernel.img kernel.img.orig) of the original kernel and the one I just built and just about every byte is different
                                kernel doesn't boot.
                                Donate to Finless
