T428 Study and Research on Experimental Firmwares
Originally posted by sam321 View PostSo I have been working on making roms for the MK802-IV. Now you are probably asking yourself why I am writing this here in this thread, well on one of my roms I had a screen scaling issue and what can I say apart from I have fixed it, and yes I checked it works on this rom tooIf my work benefits you and you want to help out the cause, feel free to
http://www.hoaby.com/android/donate.gif
so.....
are you going to share it with us??
Re: T428 Study and Research on Experimental Firmwares
Originally posted by Finless View PostSound is a know issue with 3188 devices from the start on some TVs.
Boot the stick with the TV off. Then turn the TV on. See if that works.
This was posted months ago somewhere.
Oh and also watch out the for crappy HDMI cables they supply... Of all the sticks I have, I have 3 bad HDMI cables.
Guest
A little off-topic from my vacation
How to try chromecast vs your PC (receiver software emulation)
You can test on PC Windows.
Download and install https://github.com/mauimauer/nodecast
Download and install node for windows http://nodejs.org/download/
From dos prompt type: npm install
go in nodecast folder and type: node server.js
in firefox o Chrome open this address http://YourIP:8008
open youtube on your phone or tablet and try chromecast functionality.
soon there will be also a version for Android the we can install on android hdmi sticks
So how to fix the hdmi screen scaling. Ideally this should be done by changing the kernel source code , but as strauzo thinks that the GPL does not apply to him we will have to do it through init.d now you are probably thinking that this has been tried before and did not work.
Now we all know this does not work
echo xscale=95 yscale=95 > /sys/devices/virtual/display/display0.HDMI/scale
The question is why doesn't it, and the answer is simple, when I looked in the source code of the kernel I found that they had changed a few things, you see everything created in sys folder comes from the kernel, so now the correct line is
echo 95 > /sys/class/graphics/fb0/scale
and to easily scale down your display just download this http://www.cloudstor.es/file/m1_NDk0MQ/ and put it in system/etc/init.d and reboot
I would just like to add here that I believe that everything can be solved by working together and not against each other. when developers share information with each other things get fixed a lot faster, and means that you the end user gets a better experience
Originally posted by sam321 View PostI would just like to add here that I believe that everything can be solved by working together and not against each other. when developers share information with each other things get fixed a lot faster, and means that you the end user gets a better experience
Thank you Sam321.
Guest
Originally posted by sam321 View PostSo how to fix the hdmi screen scaling. Ideally this should be done by changing the kernel source code , but as strauzo thinks that the GPL does not apply to him we will have to do it through init.d now you are probably thinking that this has been tried before and did not work.
from september i can share with all that not use the chinese rom as base. But how i can be sure about this ?
That my work is not used in chinese rom that create problems to me ? That generate work to me when i must support thousand of users with problems on this chinese rom. Because this rom are not standard.
I speak about other work, not rom development.
now that you can do all with tablet derived roms, why don't work on this rom as base rom to have a standard android rom that respect the google api and the work of other developer ?
But not worry i will share. This post only to explain my point of view.
And sam321 i apprecoate your work. I'm sure that you are a very good developer, and i like your kernel exploration. But the solution for a good software is not overklock.
A software is good if you underclock and the software work more well.
I consider all the developers of this forum friends. The problems are created by others.Last edited by Guest; 10 August 2013, 17:49.
Originally posted by Goosey View PostIsnt the chromecast just the same as the wifidisplay/miracast functionality we already have in some of these roms? What difference would there be?
WiFiDisplay (WiDi) and Miracast are technologies to mirror the screen of your current device to another display, while Chromecast is basically streaming specific media from your device, pretty much using the Chromecast display as a secondary/extra screen. It is very much like the difference between Windows' multi-screen options Mirroring and Extended Desktop, but in a more Android-compatible way.
1- You want to stream file which is not supported by Chromecast like old AVI (xvid, divix and such formats)
2- To play games from your smartphone/tab on your TV set. However, I have heard from reviews that there is sadly a lag in Miracast so maybe it will take some time to get to produce Miracast HDMI sticks perform with smaller lag to actually be useful for gamers.
As for me, if Kosh's app really let me stream content from my Gnex and tab (he will publish it whenever Google let him), then I will not need Miracast.Last edited by peteus; 11 August 2013, 21:00.
Originally posted by peteus View Post2- To play games from your smartphone/tab on your TV set. However, I have heard from reviews that there is sadly a lag in Miracast so maybe it will take some time to get to produce Miracast HDMI sticks perform with smaller lag to actually be useful for gamers.
There are currently 2771 users online. 1 members and 2770 guests.
