T428 Study and Research on Experimental Firmwares
    Originally posted by strauzo View Post
    Please, don't ask to me this. I work to restore original android on android hdmi stick 24/24 and i don't work to restore bad chinese parts.
    This is my only philosophy that I want to be respected.
    Please do you know this. Please.
    I want collaborate with all, but respect my thoughts. Please
    It could be used the other way too.. but forget it. I'm guessing I can google it up or something. Thanks.
    If my work benefits you and you want to help out the cause, feel free to
    http://www.hoaby.com/android/donate.gif
      I want collaborate with all on all android standard functionality, but respect my thoughts. Please
      About the multi-disk mounting functionality? Is it standard or another Chinese addition?
      NVidia Shield TV 2015 16 GB || Stock
      NVidia Shield TV 2017 16 GB || Stock
      Buy me a beer?
        this is a standard functioality. we can work on boot image. this not change the standard behavior of android.
        have you already tested that the multi windows mount only one partition ?
        you can see and mount the second partition manually or via external app like this https://play.google.com/store/apps/d....mounter&hl=it ?
          have you already tested that the multi windows mount only one partition?
          I'm planning to test the latest multi-window nexus rom this evening.
          But at least with the nexus rom v1 version, only one mount point is available for usb storages (i.e. my HDD mounts directly on '/mnt/usb_storage' instead of '/mnt/usb_storage/USB_DISK0/(1)' as it does with roms which include the support for mounting multiple USB storages as the same time.)
          On roms which support multiple disks I can insert e.g. a memory stick in parallel with the HDD. When I do this, the stick is mounted on '/mnt/usb_storage/USB_DISK1'.
          Buy me a beer?
            I'm working on. I have to figure out how we can solve without modifying Android
            do you have extra buttons on your mouse ? or is a standard mouse with two button.
            if you have a mouse with extra button, you can easly remap in the generic.kl that button as back button.
            android mouse button mapping already defaults as this, "browser back" button (generally the fourth mouse button) gets mapped as "back".
            is for regular mices with just two button + scroll wheel button that its a problem.
              try first with the nexus multi-windows
              and le me know
                Well thanks NixZero. I use only DroidMote that have a dedicated back button and i don't know how other android mouse work (mouse with more than two button).
                but what you say is good, for me.
                The fact is that Android already manage all well. If we make patch in not good way, specially in the android source code, we can destroy other functionality. (in the chinese roms the input managment system, apart the back buttons that can be accettable, contain a big problem, other device keys was reinterpreted as other keys)
                This is the very bad fact of android chinese rom.
                  Rikomagic 802IV works with Strauzo's kernel and Neomode Rom
                  Thanks Strauzo!! It worked! My video now using mxplayer is smooth (hardware accelaration).
                  I don't understand why Rockchip does all these chipsets without the proper software..
                    and le me know
                    Alright. With the latest nexus multi-windows rom my HDD mounts on '/mnt/usb_storage/udisk0'. If I insert a memory stick while the HDD is connected, nothing happens. If I disconnect the HDD and insert the memory stick, the stick gets mounted on the same location (udisk0). But then the HDD won't mount.
                    So the rom still seems to support only one concurrent USB mount, even if the mount point is one directory level deeper than before.
                    Buy me a beer?
                      multi window with CX919
                      I have installed your multi window ROM with the mk908 kernel on my CX919 and found the following:
                      -can not cwitch between recent apps, it always brings up the last used app, no matter whet I select from the list
                      -I have to go back to HomeScreen than bring up the recent apps than I can select that I want
                      but just pressing the recent apps button it does not work,
                      -utorrent app (the official) behaves strangely , somtimes it puts garbage on the screen, does not recognise some torrents. etc.
                      -I had to use the orientation locker app to lock the orientatin in landscape mode
                      All the above did not happen with your previous ROM everithing was fine with the same combination.
                        for recent app, if in the settings you enable multi-windows you solve.
                        if you want solve also without multi-windows active, edit the build.prop and set voiceicon=true
                        but if you set voiceicon=true (enable also volume icon on status bar), you can't enable well the multi-windwows icon from settings.
                        i think this is a little bug of the original tablet rom.
                        on t428 i don't have rotation problem. but after you put the rom in landscape, you can use also the top right bar setting to lock screen and disable autorotation. click enable and after disable autorotation.
                          Strauzo don't hold yourself
                          Keep doing you good work don't hold yourself no now and never I am happy with my T428 tronsmart stick it work great.i just notice something when I have incoming email or something is download, the device freeze a little and even the browser turn slow. Maybe the wifi controller. What do you think is the problem everything else work good.
                            Funny I noticed my air mouse gets really leggy when I'm running bandwidth speed tests. I'm using the multi window rom and 908 kernel.
                              Audio patch for switch between audio output
                              All credits of this patch to the user flakeyj
                              The instuctions are in this file:
                              <DELETED>
                              Replace/copy files in the instuctions and install the app SoundAbout (open SoundAbout but don't change default settings)
                              From this moment, when you add an usb audio device this became the default device.
                              When you remove it the default audio device is the hdmi.
                              you can switch between devices also with the app SoundAbout
                              i tested this patch with my HP usb headphones + mic (all ok)
                              test this patch and if all is ok, we can add it to the next version of nexus multi-windows
                                speed tets
                                How do you do this test ?
