leolas
T428 Study and Research on Experimental Firmwares
Re: T428 Study and Research on Experimental Firmwares
Originally posted by darrellr View Post
Sorry for OT:
@strauzo:
You seem to be quite the fan of droidmote and I would definitely like to use it aswell.
However I can not get it to work.
I've not yet installed nexus rom (will do so soon). I'm still using a Finless 4.2.2 version on my CX-919. When I let the server run and try to find it with my client (phone) via search button it does not find anything. When I directly enter the IP adress manually, the devices connect (or at least I don't get any error message). Then however nothing happens when I use the touchscreen of my phone.
It does work when I use RKRemote (phone connects without issue). But the app is a bit laggy and I was hoping for improvement by using droidmote.
Does the finless kernel maybe not include the uinput required to run droidmote? Has anybody droidmote running on finless 4.2.2 for CX-919?
Also I wanted to know how do you handle the stick before you enable the server? As I can see it you still require some kind of input device so that you can start the server?
Thanks in advance for your answers.
Originally posted by leolas View PostSorry but I cant access pc for some time, I am from my mobile and tapatalk.
leolas
The RK3188 stick + bluetooth airmouse + 64Gb SDXC seemed perfect. I could plug it into the Hotel TV's USB (power) and HDMI sockets, connect up to WiFi, and then use the airmouse to watch TV shows, read emails, browse web.
Seemed perfect ....
... except the TV shows stutter
.... and bluetooth airmouse didn't work
.... and the better images can't read exFAT drives!
Strauzo seems to have got the video sorted, Measy have sorted the bluetooth and there's a solution developed for exFAT.
It just needs to come together in the same image (with hardware accelerated XBMC) and we will be laughingMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Guest
Originally posted by finrodize View PostSorry for OT:
@strauzo:
The error that you have is because you don't have the last version from google play i think. You must use last client with last server. Otherwise you have problems as you explain.
In the settings of the original DroidMote Server settings, you have the option start on boot . only the first time that you install new firmware, with a mouse you click this checkbox and from this moment you can do all with your phone or tablet or with any other android device. Every time you start your hdmi stck the server start automatically.
Look this:
DroidMote is an app that let you control Android, Linux, Windows and Chrome OS devices. With your phone you can control apps and games that support all kind of interactions: gamepad, mouse and keyboard or touch actions. With an hardware gamepad instead you can control multi touch games and games that requires mouse and keyboard. With the DroidMote KMredirect add-on you can control multi touch games and games with gamepad support with mouse and keyboard.
AW: T428 Study and Research on Experimental Firmwares
Originally posted by strauzo View PostSure that work on every rk3066 and rk3188 with all roms.
Look this:
http://www.videomap.it/dmsguide.htm
Originally posted by darrellr View PostStrauzo seems to have got the video sorted, Measy have sorted the bluetooth and there's a solution developed for exFAT.
Source code changes are also included on the page so that might bring it 1 step closer to "getting things together".
Originally posted by phjanderson View Post
Guest
Your next step will be a rom with sdk2 and you other step will be a rom with multi-windows.
But if you want, you can use already the nexus rom multi windows that have all inside.
Video fix
Sdk2
Multi windows
Widevine drm for app like netflix
Bravia engine for better video and image quality
Many kernel modules
And more and more
Video fix
Sdk2
And multi windows
And where is the fix of Rockchip ?
Fortunately the community can now move along with progress in other areasGood job phjanderson !
Guest
Originally posted by rceccleston View PostI'm running Finless 4.2.2 ROM with Strauzo's MK908 kernel and Droidmote on my CX-919 with very good results.
If you use the Nexus you are free of patch and cinese orrors.
Or if you want use the chinese rom but you want the central button of droidmote work, i suggest to use a custom keylayout as workaround for the problem.
You can download and select the rk3066.kl from droidmote support forum.
Video fix
Sdk2
Multi windows
Many kernel modules
And more and more
Let's all work together, not compete, thanks!
Guest
Originally posted by phjanderson View PostStrauzo, I have no intention to "compete" with you. Your work on the SDK2 roms is great, I wouldn't be able to do the same. My only objection was that you didn't share your video fix and thus making the whole custom rom community dependent on you. While your work is great, no single person can handle all the requests and different types of hardware alone. I believe that me sharing the video fix can bring your nexus rom to a larger audience with different hardware from the sticks you currently own.
Originally posted by Q(^.^Q) View PostGreat work & great attitude! Thanks for hard work and time! Now we finally have working kernel w/ all bonus AND can be used with stock rom (unlike strauzo)!!!
We'll all be happier once you all set up github accounts. Code wants to be free, it found a way this time too.
Signature? Signature!
Guest
Am thankful for both! Attitudes say lots though
Now this is a true COMMUNITY fix and not all for fame of one user!
There are currently 6300 users online. 0 members and 6300 guests.
