T428 Study and Research on Experimental Firmwares
Guest
Originally posted by mabshire View PostLast edited by Guest; 10 June 2013, 09:45.
Guest
I also have the bluetooth working on the last 4.2.2 pipo rom
install terminal emulator
type reboot recovery
and install this patch
<DELETED>
I finally got a base rom that satisfies me in all. Video are very very good in all players and specially in xbmc libstagefright version. The wifi and bluetooth are very stable. The ui stable and fast. Antutu over 17400
i'm very happy
Originally posted by strauzo View PostI also have the bluetooth working on the last 4.2.2 pipo rom
<DELETED>
i'm very happy
I see you edited boot.img and bootanimation too nice!
Bluetooth patch is working nicely!! Will test its stability throughout the day just to see
Anyway in build.prop you can change screen lock and sleep to be off also?
MAJOR BUG: Thought your version of CWM might have had it fixed, but I have ntoiced anytime CWM is installed as a recovery the internal sd card is no longer mounted. Love this rom, but cannot use it without an SD card, can the bluetooth fix be applied manually?
Guest
Originally posted by alwaysbless View PostAwesome work! I am going to test here in a bit, the only other thing this rom needs now is to fix rotation, remove battery icon and be rooted and I think it will make an awesome alternative to the other t428 roms available.
I ported wifi, bluetooth and adapt all to be installed on T428.
The orientation is a minor problem, because when you set in landscape the first time. You don't have problems anymore. A little trick: long press on landscape in rotation locker and you have always landscape.
Patching the original android code to disable forever the portrait mode is another bad practice of hdmi sticks roms, because with this patch many apps can crash.
Now we have an original and very good android 4.2.2 rom for the t428.
Originally posted by strauzo View PostIt is already rooted and all necessary best parameters. The base rom is just one of the best rom for rk3188 devices. The base rom is the work of Christian Troy.
Here is systemui.apk without battery iconsSDcard still needs to be fixed though and device cannot be woken once in sleep mode so that needs to be disabled by default
U4B
Today I install U4B firmware on my t428 since specs are similar. Same firmware except for power. Now when power off the only choice is sleep mode, but now my on/off button on my rc13 work. To root this firmware I use the rk3188 from vondroïd but you need at each boot to activate in usb setting the connect to pc (by default it is off). For the video jittering it is there, but strangely when playing a 1080p it look like less jittering then 720p, maybe the coding of the movie.T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
Guest
Originally posted by alwaysbless View Posthttps://www.dropbox.com/s/mvis4f7ioyko73v/SystemUI.apk
i suggest to format the nand flash for every new rom, otherwise you can have old things inside.
if i use the external power supplies itdon't wake up , but attached to the usb of my tv it wake up wothout problems.
this last thing need a solution. but the rom is very very good specially for videos and specially for xbmc
Originally posted by strauzo View Postas i write above, at first rom installation, format the flash nand and you have the sdcard work forever.
This rom is based on last 4.2.2 for Pipo 27.05.
the rom should be installed using CWM recovery.
copy the update-signed.zip to an external sd-card
Flash with the tool RKAndroidTool.exe only:
RK3188Loader(L)_V1.20.bin
parameter
misc
kernel
boot
recovery
Power on the T428 and in CWM recovery:
wipe/factory reset
install zip from external sd card
select update-signes.zip and install
<DELETED>
Followed these exact instructions
Guest
Originally posted by alwaysbless View PostThats the very first thing I did......... sdcard just isnt working. I have tested CWM with rk3188 long before this thread, and the reasoning behind me not using it was exactly this. It breaks internal sdcard. How can I apply bluetooth fix manually instead of using CWM. Also since most users dont have a tv that can power the device via USB it might be useful if the sleep was turned off all together.
parameter
misc
kernel
boot
recovery
wipe/factory reset
<DELETED>
Only after the first installation, this is normal becouse we have installed the rom via CWM recovery. From this moment you can format the sdcard also with CWM recovery.
if you have only the external power supplies, for now disable the lock screen from settings and you don't have wake up problems. on this i can investigate.
Originally posted by strauzo View Postwell. to have sdcard working. when you installed the rom the first time, go in Settings -> Storage and try to mount the nand flash, in the status bar on top you see a message that suggest you to format the nand flash. Format and you have all working.
Guest
Originally posted by alwaysbless View PostClicking mount storage gave me a message saying "Damaged storage". I have rebooted device mutiple times since instaling however, does it only work after system has booted first time?
Originally posted by strauzo View Postwell. when you see the message damage storage, in system bar on top you have a message, click on this message that suggest you to format the nand flash.
Guest
Originally posted by alwaysbless View PostBingo! Sry about the confusion, the directions didnt say anything about doing this extra stuff lol. Might wanna add these last few steps to the directions you had posted intiallymake a good guide and organize better our work.
in this thread we are all equal and everyone can contribute with what he knows
for example i don't speak english very well and i know that i make uncomprehensible guide and how to.
i suggest to test the xbmc libstagefright version, the video decode is very very good.
i used also the advancedsettings.xml for decode of 1080p videos
This ROM is based on the latest 4.2.2 ROM for the Pipo M9 tablet (05/27/2013)
and should be installed using CWM recovery. Follow these directions to install
Before Flashing:
(1) Download ROM and Bluetooth Patch -
ROM: https://www.dropbox.com/s/7ohos9ary9...27.05-pipo.rar
Bluetooth Patch: https://www.dropbox.com/s/2y7hz2ztze...ooth-patch.zip
(2) Insert Micro SD card into PC
(2) Extract the downloaded ROM file from the above link to any easy to find location on your PC and copy the bluetooth patch zip file to your microsd card (DO NOT extract)
(3) Next, in the extracted ROM directory right click and copy the update-signed.zip to the micro sdcard and then remove from PC and insert into your T428
(4) In the same folder as the update-signed zip open the RKAndroidTool.exe
(5) Hold the recovery button on your T428 and insert its microusb cable into your PC.
(6) Once the status of the RKAndroidTool says "Found device", perform an eraseIDB and then select and flash only these specific files:
• RK3188Loader(L)_V1.20.bin (must change path to use V1.20 and NOT V1.00)
• parameter
• misc
• kernel
• boot
• recovery
After flashing:
(1) Wipe/Factory reset & Clear Cache
(2) Install zip from SDcard > Install zip from external sd card
(3) Browse to location of update-signed.zip and install
(4) Once installation has completed select reboot and boot device for the first time
(5) Once device has booted and has gone through the set up process open the settings application and select "Storage"
(6) From the storage menu under NAND flash select "Mount" (it should give you an error in the status bar)
(7) Once you see the error click it and it will ask you to repair/reformat the internal sd card and you're all done!Last edited by alwaysbless; 10 June 2013, 18:20.
There are currently 2010 users online. 1 members and 2009 guests.
