I am using stock 4.2.2, so I need to flash with pipo with the rockettool and then apply updated in cwm. I already have cwm install.
T428 Study and Research on Experimental Firmwares
Guest
Originally posted by alwaysbless View PostWouldnt all USB power adapters be considered external? What type are you using? I have tried From my t428, mk808, nexus 7 and nexus 4. Outisde of antutu restarting the rom hasnt given me one problem it seems stable but I feel like my t428 is either not getting enough power or its GPU cant handle the frequency that its running at (always crashing during the 3d scene in the field).
http://www.amazon.com/Genuine-Adapte.../dp/B00A72LC6C - Gonna order one of these I think
without a good power supplies, in all roms you can't do antutu
look the link above for the new link
Guest
Originally posted by strauzo View PostI use the one that come with T428. The external power supply of 2000mA
Guest
[QUOTE=strauzo;72105]This rom is based on last 4.2.2 for Pipo 27.05 + work of Christian Troy of Dragondevs
the rom should be installed using CWM recovery.
copy the update-signed.zip to an external sd-card
Flash with the tool RKAndroidTool.exe only:
RK3188Loader(L)_V1.20.bin
parameter
misc
kernel
boot
recovery
Power on the T428 and in CWM recovery:
wipe/factory reset
install zip from external sd card
select update-signes.zip and install
<DELETED>
The base rom is the work of Christian Troy of Dragondevs
i suggest of format the flash nand after the first boot. storage -> flash nand -> format
Guest
With the last rom the xbmc libstsgefright version work very well for me.
Someone have different result ?
Originally posted by strauzo View PostWith the last rom the xbmc libstsgefright version work very well for me.
Thank You strauzo
Thank You strauzo. I was able to install the Cloadworkmod recovery and your rom.
Here are the steps that I followed:
1. Installed the CWM as per your instructions
2. Copied the Zip file to microsd card and inserted into the t428
3. In the CWM I have installed with external SD option
4. Rebooted the t428 after the successfully installation of rom.
There are currently 1456 users online. 2 members and 1454 guests.
