From my experience and after testing several f/w i ended up that mo123 Lollipop roms was the best match for my needs.
I have Tronsmart R28 Meta with 2G/16G and BT, WiFi is working ok.
If you have a 4K TV then use Lollipop firmware 1.7b, If not a 4K and you want only 1080p then use 1.8a, If you have 720p TV then 1.8.
In 1.7b the HDMI bit-stream works perfect but if you root the device you will have problems with Google apps.
In 1.8a the HDMI bit-stream does not work (you can use SPDIF for 5.1 core) but everything else works perfectly.
The HPH Launcher in this roms is very nice and neat and the network (Lan in my case ) is very fast.
The embedded version of Kodi (NTMC) is very smooth and fluent in any video i tested (even in H265 HEVC with 10bit).
The last release 1.9 is almost perfect just a small issue with screen scale that it is not so obvious (the screen does not reach the 100% of the TV, is approximately 99%).
Note that in the above roms the Tronsmart remote does not work.
