HPH RK3288 Lollipop ROM v1.6 By Mo123
Originally posted by mo123 View PostRK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by mo123 View PostI need some users to test if
Netflix audio sync is better and also
HD Audio Pass-through in latest Kodi 17 beta 6
They merged lots of pass-through changes that are compatible with my firmware so will be interesting to know what works.
http://ftp.halifax.rwth-aachen.de/xb...rmeabi-v7a.apk
Can use this spreadsheet to test some videos and download them
https://mega.nz/#!cMlBgSiI!GsVLADwqm...omFxpiqed2Ulbs
NTMC should be able to work with most videos correctly.
But need some feedback about the latest Kodi 17 above and how it works.
Any file i tried (samples or movies) with DTS, DTS-MA, DD, DD-TrueHD played as PCM in my Yamaha RXV781 receiver.
I tested it with 1.7bLast edited by orionas21; 08 December 2016, 15:15.
Originally posted by orionas21 View Postmo123
In your last rom 1.8 i hear noise in NTMC RKMC (last version) and MXplayer.
The Google play problems corrected.
Also Android Settings - Sound - Set to HDMI Bitstream?
In NTMC can also try setting 'keep audio device alive' to never or always.
In NTMC also need to enable relevant AC3/DTS sound settings.
Other users reported pass-through sound working.
Can you check if you have the latest firmware installed for your audio receiver?
Nevertheless i checked and i have the latest firmware in Yamaha.
I tried everything before reverting back to 1.7b.
I even played with HDMI mode 720,1080,4k and in several refresh rates.
I tried color modes.
I tried with sound default & HDMI bit-stream
In NTMC & RKMC i tried with enabled/disabled refresh rate sync
With never / always the keep audio device.
Enable and disable pass-through on the fly (during playback).
Enable & disable pass-through from settings.
Enable & disable RKcodec, Mediacodec, Mediacodec(surface).
The same in MX with HW decoder in sound. with SW decoder in sound, with HW+ decoder combined with SW decoder for sound.
My receiver is connected to internet and has auto update enabled.
If you still don't have correct sound then something is wrong with your setup as MXPlayer runs independently of the rest of the firmware system files.
Go into MXPlayer settings and download the external ffmpeg codec, then use it as the default ocdec.
https://www.3nions.com/fix-ac3-audio...-in-mx-player/
The same codec i use in 1.7b and plays correctly.
i noticed that in 1.8 the libffmpeg.so and libmxffmpeg.so are different than 1.7b.
Could this be the problem?
When update i even wipe data before the flashing. just leting you know.
Mo123 I hope my request is acceptable, if not please let me know.
Thanks!
Originally posted by Shomari View Post
If not too late, would you mind sharing your Kodi debug logs as well as your dmesg log output during your testing? You've done a very thorough series of tests. I'm banned from the Kodi forums so this is the only place I'll get to see logs, if at all.
Thanks!
I will try it again this weekend if i can.
I have rollback to 1.7b and i do not have the logs.
There might be a problem with the firmware also, there are lots of HDMI-IN sound code I didn't remove and in the v1.7b firmware I disabled some but can't remember exactly what, so will try something later.
There will also be new firmware in a week or so with the latest code and bugfixes that should work even better.
There are currently 4439 users online. 1 members and 4438 guests.
