HPH RK3288 Lollipop ROM v1.6 By Mo123
    Originally posted by m1pnk View Post
    same here on lg new 4k
    You can try to change the Color mode to RGB_255 in Android Display Settings to help with this problem.
    Check when rebooting or powering on from standby then still has the purple screen or if it is gone?
    If it works, I can try to make it default on first boot/install.
    There might be something else also causing it, I will just try to see if I can find it.
    On RK3368 I didn't see this problem.
    I think the problem happened because of the new U-boot that has changed a lot.
    I think the old u-boot can also be flashed back and will solve lots of these problems including 1080p resolution not remembered on some tv's.
    I will experiment a bit.
    You can also try to pause a video after a while and play again and see if audio for 5.1 Dolby is correct again.
      Hi mo!
      ıs there any news about marshmallow rom for rk3288 chipsets? I want to use xposed on your roms. (or any news about remix os)
        Originally posted by beacool View Post
        Hi mo!
        There is Phoenix OS(like Remix OS) but I still need to experiment with it.
        I will also test Marshmallow but will probably only make a basic firmware first.
        It might take 1-2 weeks.
        .I will release a new Lollipop firmware in the next few days.
          I ll wait your next marshmallow firmware. And if its based on Phoneix Os it will be great!!
            What problems are people still experiencing with RK3288 firmware?
            Please report your problems.
            - Resolution not remembered after reboot - Found the problem, will test the solution
            - Pink screen on boot - already fixed
            - Playback of interlaced video - now showing in RKMC
            - SD Card not working correctly - still investigating
            Does this help with the SD Card problem or not?
            https://play.google.com/store/apps/d...pp.sdfix&hl=en
            Can also try formatting the SD Card with this app
              https://www.sdcard.org/downloads/formatter_4/index.html
              Hi
              Looking forward to the next version - what about the netflix lag ? Did you found a solution to that as well ? And I got a problem with on/off - I can switch the box off - but then I cant switch it back on again.
              The button on the box just doesnt work (I have to pull the power plug in order to switch it on again). And one more thing, the square button in the GUI where you can select open apps or close them all - the latter is missing from your rom. It could be nice to have "close all apps" button like on the original Ugoos S/W (3.07)
              Hi from Claus
                New v1.7b ROM
                https://mega.nz/#!dJlACYZI!pUr7cbLzjvHm5gsoPzBbTxRF_O02C9eTnYhAj9hhDDM
                Pass: nagrace
                - Fixed Pink screen on boot on some setups
                - Interlaced content can now be played in NTMC
                Only tested local video playback
                Please test Live TV PVR addons with 576i/1080i streams
                - New Codecs
                - Display Options - Auto Frame-rate switching
                Please experiment with the 2 settings in different video players.
                For Netflix
                Please test with:
                Screen resolution - 1920x1080p@24hz
                Display Options - Auto frame-rate - Video resolution priority
                  HI Mo
                  nice to see i can test it on my UT3.
                  once again nice Day
                  gefattern
                    HI Mo
                    once again nice Day
                    gefattern
                    Yes, you can test it on UT3.
                    The NTMC Kodi works very well and better than others.
                    There might be small bugs, but if people report them, it will be easier to fix.
                    The launcher will have the same days English text as RK3368 firmware.
                    It is a bit tricky to fix and I need to build complete firmware again, so if I can fix other bugs together with the translations it helps, I can then upload a new firmware with more changes since my upload is very slow and it is difficult to do uploads for small changes.
                      I need a tester with an HD Audio receiver that can test DTS-HD, Dolby Atmos etc. on my firmware.
                      If you can help, I will send you something interesting to test.
                        Hi Mo, hope all is well with you. Can't download 1.7b with your posted link. Even with the "nagrace" password, Mega complains that it needs a proper decryption password...
                        Edit: OK, had to clear my browser cache. It worked fine after that. Sorry for the false alarm.
                          1.7b wifi not working
                            What device do you have?
                              hph nt-v6
                                hph nt-v6
