HPH RK3288 Lollipop ROM v1.6 By Mo123
New ROM has been released.
https://mega.nz/#!hEF3yJLa!jsZUrcaCa...EEqu4G3g54MWYo
[SIZE=14px]- New Rockchip Kodi 16.1 with standard Audio API support
*Framepacking 3D
* HDMI-24hz Bluray 3D
*Auto Switch HDMI-3D Bluray 3D
- Fix sound problems with games
- Casting/mirroring support
- Fix the Dolby Digital Plus problem
- USB webcam mic fix
- OK Google support
- Fix ES File Manager black background.
- New Security patches
- NFS support
- 'Lacie' hard drive support
- HDMI-IN support for supported devices
- Also works on Ugoos UT3/(S) devices
Please test new Kodi and also SPMC and provide Kodi logs + logcats if there are any problems.Last edited by mo123; 27 May 2016, 05:13.
Originally posted by gefattern View PostHi Mo
i give it a try after i have tested the 3.0.6 from Ugoos,but what i already can say over 3.0.6 : Still Stutters in Audio & Video with Wifi on/off nothing.
Have a nice Day
gefattern
What audio are you using?
Bluetooth speakers, HDMI or SPDIF?
Also can you give some sample videos that cause these stutters?
What video and audio settings are you using in Kodi/RKMC?
Can you provide a RKMC log with ethernet and one with wifi while playing these videos?
Can install Kodi/RKMC log uploader from Program addons.
Maybe it will help and the problem can be send to Rockchip.
Or maybe it can be fixed with different settings?
The more information you provide the better.
Originally posted by m1pnk View Postwell new firm looks great mo.... only one prob here... aspect ratio ..... all playing back in 16.9 and not 21.9 ..... distorted pics...... no mater what i changed or look for cant find option to adjust.... thanks
yep... with rkcodec acceleration on its giving wrong aspect....
then try the 5 options.
Can you post the resolution of the videos/streams?
I think the brightness, contrast settings are also missing.
You can also try to disable - RKMC - 'Accelerate RKCodec
or also - Acceleration - Both Mediacodec's to use software rendering that have more options.
If I have more info, it can be send to Rockchip to add into their Kodi.
Hi Mo
first of all i use HDMI/Default with an old Typhoon 5.1 Soundmax DD System with / 2Boxes / 1Bass / 1 Center connected to TV.
I always delete this Kodi and others i use RKMusic & Stockvideoplayer.I am not a Kodi Junkie,nearly every
Post has do do with this .I dont have fast Internet only 3g Router max 7.2 Mbits and want to use it for Gaming
Surfing & Music.
In my City Kodi is a Market were you can buy cheap Plastic Junk and others for Kitchen and House.
I ziped the Videos that i use and will upload them tonight if it works??? If u want Logfiles i can only make Catlog
Files.Somewhere here i had read something about Problems with some Wifi Frequencies 2.4 or 5 i dont know???
Mo but first i have to test the Ugoos 3.0.6 .
have a nice Day
gefattern
There are currently 2556 users online. 0 members and 2556 guests.
