HPH RK3288 Lollipop ROM v1.6 By Mo123
    Originally posted by Chris_Gee_ View Post
    Yeah , the adb issue is a strange one , I never had any problems on the 1.7 rom transferring files using es file explorer , it's only recently it's stopped working , the only thing changed my end is my phone has upgraded to marshmallow (not sure if that would have anything to do with it ?) i'm sure on the 1.7 rom i didn't have a problem selecting a higher resolution on the same HDMI cable.
    Might be a Lollipop problem.
    They are working on new stock firmware that should fix all these bugs.
    But I'll also just see if I can change something in the kernel/resource.img for adb that might help.
      Hi Mo , this is what I get on both 1.7 rom and the new lollipop rom , also noticed that the lollipop rom my wifi speeds are very very slow , i reflashed my box back to 1.7 and the speeds were like night and day and the resolution auto selected to 4k @ 30hz , But I still wasn't able to connect to it via adb using es file explorer on my Galaxy s7 which makes me think it could be a marshmallow problem ?
        Is there any specific reason you need to use adb?
        Maybe there is another way to do what you want?
        It might be a Marshmallow/Lollipop compatibility issue.
        I will just test the wifi speed.
        How did you test the wifi speed on Lollipop, then I can just try to do the same and see if there is something to change perhaps?
          I just find it easier to download the zip file and send it using my phone to the box via wifi saves me having to load up the pc , put it on a usb stick and do it that way .
            First little problem i cant instal mx player pro and cant uninstal mx player
              You can root and use 'system app remover' to remove MXPlayer and install the Pro version.
              The only way to integrate MXPlayer is to make it a system app otherwise it couldn't load.
                Hi Mo , iv'e reverted back to the 1.7 rom as I think it works so much better , I installed speedtest from the play store and was struggling to get 8meg on the download with a 100meg fiber broadband , also bought a high quality hdmi 2.0 lead and it still it couldn't activate 4k on my LG Tv ....very strange , The adb thing I guess I could live with out until there's a fix , The 1.7 rom works great though no problem finding the 4k resolution and the download speeds are miles better (I cant test it though as speedtest wont install for some mad reason on 1.7)
                  Solved thank you Mo
                    Hi Mo
                    when will you release the HDMI IN Firmware????
                      Hi Mo
                      Hi
                      What HDMI-IN firmware are you currently using?
                      I plan on releasing a new firmware next week if Nagrace & Rockchip finish their latest work.
                      There are some interesting projects Rockchip is working on.
                        If I know Rockchip punctuality then we will wait till the end of next month at least .
                        RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
                          Mo, i flashed my B368 box and is working very well...will be glad if you can repack my resource.img from Kitkat to Lollipop to enable me use the stock remote.
                          http://www.4shared.com/file/6YyrOKQRba/resource.html Thanks
                            To root go to 'Android Settings' then 'Accessibility Options' then you can enable or disable Root there.
                            It is much better than pre-rooted because some people use streaming apps that don't work with rooted ROM's then they can switch it off and for apps that require root, you can enable it again.
                            On non-HPH or Ugoos devices the power light and IR won't work.
                            You have to swap your resource.img & kernel.img from your manufacturer's stock firmware but then loose some optimizations and Lehome assistant support.
                            Even on other RK3288 devices people will have a different experience with the ROM because of slower RAM/EMMC storage etc.
                            On HPH and Ugoos hardware the ROM is extremely fast and gets over 50000+ Antutu score.
                            I put a password on the file because lots of people just post other people's things on the internet and then don't show where it originally comes from.
                            On my B368 Antutu hit 53000+
                              Hi Mo123,
                              I'd just like to report a bug with the power on function using this firmware, relating to HPH_NT-V6
                              The power button will turn off this device, but the power button will not turn it on..
                              I have noticed that if you hold it in for 5 secs, the boot screen starts, but as soon as the button is released the box switches off.
                              Also via the remote, the box will switch off but it will not switch back on, even with a long press of the power button on the remote..
                              I hope this helps with any fault finding..
                              Again thank you for the firmware..
                              Technowhizz
                                Hi Mo,
                                i have a UT3,maybe i understood something wrong,i thought the Firmware has no HDMI IN App. (to plug in a Tablet & show the Screen of the Tablet)
                                Because the UT3 has this Function.I am still on 2.2.0 KK Rom.
                                Is this correct Mo ???
                                gefattern
                                Last edited by gefattern; 15 April 2016, 16:46. Reason: because of this (   ) always shown in the Text if i save the Thread
