Can you or someone with the resolution switching post a screenshot perhaps of 'Display Settings' where it shows all the resolutions available to choose on a 4k tv?
Eg. on a 1080p tv it stays at 1080p@60hz but that is the highest resolution on a 1080p tv.
I will see if it is a simple setting to change otherwise it might require a bit more investigating.
Did the problem not happen on the previous stock firmware I send you, did it remember the 1080p setting correctly?
