I tested stereo 2.0 sound on 'default' sound device and also 'HDMI-Bitstream' and it worked.
If you use pass-through sound, did you set 'HDMI Bitstream' in Android Sound Settings and also enabled pass-through in RKMC Settings?
It would be interesting, what happens if only flashing loader from MK902II and using firmware with kernel/resource.img in post 114.
Does pass-through sound then work?
I use the same kernel/resource as in v1.4 firmware where pass-through works, just system, loader changed and added HDMI-IN support.
I still have to pinpoint the problem with HDMI-IN.that stop other sound.
Does pass-through sound work on v1.4 firmware in middle of 1st post in this thread in NTMC?
