HPH RK3288 Lollipop ROM v1.6 By Mo123
Originally posted by newer View PostThis my first time upgrade 1.9 to my Tronsmart 3288 Orion R28 meta,every thing seem work great but only my original remote control not working?can you help please,thank you
If you have a smartphone you can use the RKRemoteControl app or use a usb keyboard and mouse.
Originally posted by icemanbrfc View PostMo downgrading to firmware 1.8a definitely fixed my audio issues. You might want to have a look at that in 1.9. Not sure if it's only me, or if something went a bit wonky when doing the upgrade to 1.9 on my side, but worth a look.
-Chromecast with Google TV
- Android Q Android 10
Might be a driver or small pin configuration change.
I will post a small file to flash to check if it solves the problem later.
Originally posted by mo123
I'm looking into it.
I will post a small file to flash to check if it solves the problem later.no stress though, as 1.8a is working great. Netflix audio sync is in line which is good. And my beloved sleep option is there hahaha
Originally posted by orionas21 View Post
HDMI bitstream works great. That is for sure.
Could you include in the fix also the scale solution?
Scaling to 100%
ES File Explorer black screen fix
Latest NTMC
Exfat support
SPDIF fix
Then I also work on RK3368 & RK3229 firmwares, so a lot to do.
thank you
You can download it from play store in your phone or tablet and you have to enable it in the device (is already embedded in the HPH firmware) under Settings --> Accessibility.
There are currently 3564 users online. 0 members and 3564 guests.
