UPDATE - Marschmallow - Wasser Firmware for Beelink R89
    Hi Wasser, hi all
    thx for your work.
    Beeling R89B v.3.1 2/16GB
    I also installed 4.0.0 over 3.02 with Android Tool 2.3
    For the first time Win 7 detected the box as an drive.
    Picture over AV, smile, but it is too large.
    Cherry wireless mouse works good, i can change the setting and it seems to work.
    I open the ES-Explorer to see my ext. HDD or USB-Stick but no setting changes seems to work.
    Lan works good.
    Also to testing the box i must adjust the screen.
      4.0.0 alpha1 Feedback
      Installed over the top of the most recent LP ROM with factory tool 1.33 with no issues at all.
      Noted that the ROM is not rooted, so would like to know the best tool to use to root.
      No HDMI or SPDIF passthrough options available.
      Box detected by PC as a storage device by default (no option to select type i.e. MTP, Mass storage etc ) but nothing available when you look at it and no data can be written to it.
      Just found the option in Developer options, which is not where I expected it to be (now called Select USB Configuration)
      Changing to PTP does enable access to DCIM and Pictures.
      All regular settings that are available do seem to work
      WiFi seen on both 2,4 and 5Ghz channels and connects to each without issue.
      5Ghz speed very impressive.
      Ethernet good too.
      No options on the home screens for reboot/sleep etc, so looks like an app will be required although with no root, this may be difficult.
      Tried adb shell reboot -p from my PC to power off but returns an error that the device is unauthorised, so power off may have to be via the button until I can achieve root.
      UI is smooth and responsive.
      External SD card showing
      More later when I can get Titanium backup running to restore apps and test further.
      1. "root device" is fixed abd will be included in next release
      2. HDMI/SPDIF passthrought options are still missing. i am still working on it
      3. poweroff button in homescreen will be included in next release
      Thanks for the the testing abd feedbacks!
        Originally posted by digitalriver View Post
        or install 3.0.5, after go to recowery, wipe data&factory reset, reboot to bootloader and install 4.0.0.
        So:
        Work twrp, its good, but:
        1 no root ( I am trying to install SuperSU v2.74 beta,Supersu v2.67 pro,as apk, as recowery zip, but unsuccessfully )
        2 not work camera
        3 small problems with UI in russian language(not work page "display" in "setting")(english UI - all good)
        4 autorotation work badly with some programs
        5 android does not see external sd-card
        1. is fixed
        2. know issue, it's on my todo list for next release
        3/4 know issue
          Originally posted by wasser View Post
          1. is fixed
          3/4 know issue
          I hope to have Miracast on the next version
            Hi Wasser,
            Thank you for your support of the ROM development.
            My device:
            Beelink R89 2G/16G
            PCB ver 3.0
            1080P@60Hz
            Gigabit Ethernet
            FW 4.0.0 alpha1
            This is the first ROM build that I tested with true stutter free in YouTube 1080 video.
            Stutter is occasionally happened even in stable FW 3.0.2. (Not all 1080 YouTube video. There is stutter even the video is not 1080P60)
            Another thing that I noticed RKRemoteControl is working again!
            I am really surprised by that. Excellent!
            Features missing
            1.) External device cannot be mounted. (All my external devices are EXFAT file system format. And I cannot test the video playback in MX player caused by the mounting issue)
            2.) Android navigation bar cannot be hidden
            3.) Clear all recently used apps button (But it seems that this feature is also not available from the Nexus device with stock Marshmallow ROM)
            4.) Hidden status bar is sometimes dragged from left or right hand side (I don' t know it is issue or not. But Lollipop' s status bar is dragged from center at all times)
            Root issue, power button issue, auto rotation issue have been already reported by other members.
            Regards,
            Sintest
              Great stuff.
              Look forward to it.
                How?
                Flash the image using the factory tool.
                I tend to find it works more reliably than the android tool.
                  wasser splendid work
                  mk902II working stutter free for first time after A4, all A5 roms gave me stutter but not this one
                  rare force close but really rare...
                  don't use bt or wifi so cannot report...
                  missing hide buttom bar (known and you said will be fixed)
                  reboor and root you said will be fixed...other works fast and great
                  best rom in years
                  keep the great work young padavan
                    best rom in years
                    Wifi /network and Bluetooth all work in mk902ii? Did you flash complete rom or split and flash resource to this device?
                      Just loaded on mk902ii. Wifi /bluetooth do not work both usb ports at sd card side do not work. Sd card not seen and cards not seen as installed. Great work wasser it boots and runs but inly if you load 3.0.6 first. But great to m on the 3288 devices.
                        Here's how to flash by shorting the two pins on the circuit board. https://www.youtube.com/watch?v=K9lLJirKEIQ
                        Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
                          Awesome work. Great to see Marshmellow on the R89. Is this magic comming from a new SDK from Rockchip ?
                          Also: Does Xposed work ?
                            Originally posted by bloodgnome View Post
                            Does Xposed work ?
                            installing, but not work, because superSU not work. In 4.0.1 must work
                              Outstanding. Running this on my Beelink R89, with wonderfully fluid video in YouTube/Netflix. The best I've seen on an android device. Fast interface, excellent 5ghz wifi, BT working, USB ports working, Ethernet working. As others have noted, external SD card not seen.
                              BUT - I can't keep it as a daily driver because several of my favourite Kodi addons run without audio! BBC Iplayer, Phoenix and several others. When that's fixed, this will be my rom of choice. Well done, Maestro, another triumph in the making.
                                Hi All, marschmallow wasser firmware version 4.0.1 beta1 is released. For more infos, please take a look at the first post.
                                Enjoy and please don't forget to post feedbacks!
                                Wasser
