UPDATE - Marschmallow - Wasser Firmware for Beelink R89
I`ve notice two annoying problems, first and most problematic is that on youtube the videos wich are uploaded at 1080p 60fps only can be seen/stream at 480p and the second is that the player wich is integrated on the browser dosen`t work, those three circle are runinng and the video can`t begin/run. I think that at least untill you ad the 1080p 60fps option you can fix that problem and that format 1080p 60 fps can be seen at least at normal 1080p on the next release. Rest of the rom work very good, keep the good work👍
Using the lastest beta I messed up the SuperSU by trying to flash the latest pro via TWRP. Now I don't have SuperSU anymore and can't install it again (without reflashing). Any Ideas.
Will test TV-Out later...hope that this will be the first Version after 3.0.4 that works on my old TV.
Over HDMI it seems snappy and fast and Xposed is working too. Good work Wasser.
PS.:
I miss the "old" Power Menu with "Boot to Recovery" and "Boot to Bootloader" ect. Hope we can have that back in a future Version.
Originally posted by bloodgnome View PostUsing the lastest beta I messed up the SuperSU by trying to flash the latest pro via TWRP. Now I don't have SuperSU anymore and can't install it again (without reflashing). Any Ideas.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM 792MHz@1.2V Wasser's 3.0.11 firmware
I have tested my Sandisk 64GB usb drive(exFAT), but with no luck. Testing the usb drive with other devices (PC, android phone) is fine.
YouTube is as smooth as previous release. No stutter for 720 and 1080 video through Gigabit Ethernet.
MX player video playback (720 and 1080) is also smooth through network stream. (HW+ setting is enabled)
Here are some bugs that I found in Beta 1. These items worked in previous builds.
1) Microsoft Mouse is very jerky.
2) No option to select SPDIF audio in Settings > Sounds
3) No SPDIF audio
4) MX Player with 1.8 codec - dropped frames on Avatar movie MKV (30GB File)
5) Screen flashing during movie playback and during normal app usage.
6) Beta 1 doesn't support video output to my computer monitors. My monitors use an HDMI to DVI converter. I don't have an HDMI input on my monitors.Last edited by amclean123; 10 July 2016, 06:53.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by andreyh View PostHi Wasser!
Do you have plans to fix auto hardware deinterlacing in this version?
I don't want nagging you but will there be support in foreseeable future for multi windows?
Beta 1 is quite good for me with few exceptions that I can't easly correct:
1. No HEVC 10bit support.
2. No SD card support. Tommorow I will check if it is resolved in beta 2.
3. Tincore Keymapper doesn't work as expected but it might be its own fault.
Some issues I solved with external apps help:
1. After longer sleep my TV Box will not wake up. Solution: use CPU Awake.
2. Vold doesn't mount USB memory regardless file system in use (not FAT32 nor NTFS). Solution: StickMount.
3. YouTube app doesn't display HFR video (50/60fps) and what's more for such clips it doesn't allow to choose 720@30/25 even it it available. Solution: use Chrome Browser and press pause button there few times to start playback.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM 792MHz@1.2V Wasser's 3.0.11 firmware
1 Support, works fine with mx player 1.7.40 and with internal videoplayer. But not work in ZDMC - black screen.
2 Support and very-very-very nice(Thanks Wasser!!). Sd card now can to work in 2 modes:how removable memory card, and how internal memory!!! Works fine!!!!
There are currently 6291 users online. 2 members and 6289 guests.
