i've been always fond of getting smooth video playback without the need of autoframe rate switching , (wasser's MM's roms and mo123 1.5 rom were able to achieve that VIA KODI , but unfortunately with the lack of spdif passthrough support in wasser's case).... thanks
UPDATE - Marschmallow - Wasser Firmware for Beelink R89
oh lord , i believe i should minimize directing the Qs.... but thanks for the effort and dedication to reply back bluesmanuk.
Originally posted by gridlock View Postoh lord , i believe i should minimize directing the Qs.... but thanks for the effort and dedication to reply back bluesmanuk.
Any time.
We all help each other out when we need it, so it's all good.
To have an MM ROM for the RK3288 is great and considering how long it can often take for one to be perfected, this has come at lightning speed and is so close to being as good as we could possibly expect.
I'd be willing to bet that Kodi passthrough will be working very soon indeed and will have the complete pleasurable playback across the board.
As RKMC also matures in development, that should add to the experience.
If only Rockchip had pulled their fingers out a long time ago, the RK3288 could have been king above pretty much all others for a good while.
.... , the RK3288 could have been king above pretty much all others for a good while.
Originally posted by BTR11 View Post
"version 4.0.8
* improved nfs mount --> I´m not sure if this produce a strange name when an USB unit is connected, appear name with numbers and letters like A0DB-39FF but not usb1, usbstorage1 or so...?
Does anyone else notice that the HDMI video is smoother when SPDIF audio is used instead of using HDMI audio? I've noticed this since 2.0.9. I use MX PLayer 1.8 (and codec) and ES Media player since those two video players seem to produce the best video quality lately.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by BTR11 View PostThe problem with the USB units or external SD it´s not only the name; the applications can not write on it; I use some apps to write to the USB or ext SD card (recording or caching on it) but that does not work here; I think this is a bug on v4.0.8.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View Post
Did you use any previous MM version? I don't know if this is new bug or rather MM restrictions aren't known to you.
But to interchange media and photos it´s in both way from the card to the device internal memory and from device internal memory to the external SD card?
So you are trying to say that in MM if one external SD card it´s not used as "internal memory" the user don´t be able to write on it?; these external storage would be a "read only" devices in MM? If this is a "MM´s restriction" that´s a real bad thing in case of being true; this is a not sense change. Do you have experience with other MM device like any Google Nexus? what is your understanding of this?
Originally posted by BTR11 View PostNope, this it´s my first contact with MM; I had been wondering about that menu that appear as soon one USB or SD card is plugged to the device;
Originally posted by bluesmanuk View PostTry 1.7 without the codec and see what you think of the smoothness then.
I did notice the older version seemed to be better.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Is your Titanium problem anything to do with write access when backing up by any chance?Last edited by digitalriver; 27 July 2016, 21:32.
There are currently 1550 users online. 0 members and 1550 guests.
