UPDATE - Marschmallow - Wasser Firmware for Beelink R89
Originally posted by digitalriver View Postnot only you. I have problem with usb otg too. And disabling/enabling "connect to pc" in settings dont help
I think, you have another box. For example, your box with 16GB ROM, but my box with 8GB rom.Last edited by BTR11; 28 July 2016, 23:00.
Originally posted by digitalriver View PostAlso camera not work on 4.0.8....in different usb socket....otg, not otg, no difference.
One good thing that I had not tested before as well is that I had confirmed now that the R-89 built-in microphone works Ok.
Originally posted by digitalriver View PostAlso camera not work on 4.0.8....in different usb socket....otg, not otg, no difference. After connecting and restarting not work: all videoplayers, window "sound" in "settings"(why only sound setting????), spontaneous reboots and lethargy. After disconneting and rebooting - all work. Sooo... not work camera, not work keyboard....obviously problems with USB drivers
P.S Enabling/disabling "connect to pc". "charging/mtp/ptp/usb ethernet etc" not help absolutely
It will be fixed in next release.
4.0.9 Feedback
Everything as before and discussed, so will focus on new features/fixes that I am able to test.
Adjust refresh rate working better if HDMI mode set at 50Hz as default (this may work better at 60Hz for other regions where this is the default) rather than with 60Hz as default.
Best demonstrated when playing burosch1.mpg, where it is much smoother when default is set to 50Hz.
Colour mode options all present and correct and selectable (using Auto at present)
USB flash drives detected and usable as discussed earlier today.
Last edited by bluesmanuk; 29 July 2016, 01:04.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by claudecir View PostIn Dolphin browser - > Config - > advanced - > Agent - > desktop (second) if you set this agent and play videos on YouTube (vp9 in this case) in 1080p, audio sync problem appear.
Enviado de meu LG-D802 usando Tapatalk
Do you have a specific example that can be tested.
Tried a few videos using the same settings and audio/video sync was fine but not 100% sure whether they are all being played in VP9 format.
Hi wasser, thanks for the new release v4.0.9.
I´m currently testing it, but I had noted a regression regarding to the stability of 5Ghz WiFi; I set the right region and connect; but after a couple of minutes the connection is lost; I have to reconnect, but this is ocurring frequently to me; i HAD swicthed now to ethernet to can work, but with the Wifi problem I think I won't stay with this version.
I had tested the USB camera, with some problems had started to work and produce image, but I cannoyt continue becuase the system get frozen. I have to disconnect it and reboot the device to can continue working; so, however the camera start to work, it cannot be used because the system crashed, currently still is not functional.
I will test the other aspects...
I can see the issue in Dolphin but when I create the same scenario in Chrome, I can see no issues.
The youtube app not Play movies in vp9 only h264/AVC...
Vp9 have low band consumption and is very important to low use band.
Thanks.
There are currently 2465 users online. 1 members and 2464 guests.
