UPDATE - Marschmallow - Wasser Firmware for Beelink R89
    Originally posted by giorgoxxi View Post
    Quick question, I'm on Wasser Lollipop and want to upgrade to this Marshmallow build. Can I upgrade remotely (i.e. transfer the file to the box and upgrade without plugging the PC)?
    No.
    You have to flash through the PC and appropriate Android tool.
    Backup anything important that will be lost first as the box will be wiped.
      Originally posted by keppi2456 View Post
      Hi can I use this version Orbsmart S92 here for my TV box?
      Here a link to the box: http://www.myhdplayer.de/Orbsmart-S92-Android-51-Quad-Core-Mini-PC-4K-Ultra-HD-MediaPlayer-Smart-TV-Box
      Or are there other ROMs?
      Thank you for an answer!
      Greetings Armin
      Most probably yes.
      It has the same SoC (RK3288).
      I do not know if WiFi or BT will work since this devices are not in the SoC but different chips with drivers in the Android.
      So you can give it a try and if something does not work you can easily revert to the official firmware.
        What ist the best Kodi/xxMC for Wasser v4.x?
        I test RKMC and Supercelerons Kodi, but I have on both with Passthrough over HDMI dropouts
          I like SPMC, sounds is always working contrary to Kodi. Try it.
            Thx, I have test it. But 3D dont work. Only flickering without switch from TV to 3D mode an Passthrough dont work
            I'm back to Wasser 3.0.3
              Wane try this one, but still some sound issues.....I dont know how far wasser is at the moment with an update for this rom....Wane update it, kitkat drives me crazy sometimes...Sound volume drops till zero, sometimes its busy with something what interrupts the music you dont wane know.....How many times i have adjust it while playing.....Just music....If you have to walk to this box 5 times in a half hour, to put up the volume, besides that the music is the whole time interrupted....Looks like the box is busy with something , what i dont know.....I really hope Lollipop and at the end Marschmallow will have a better experience then what i describe....But think gone take some time to bring out an update...But does anyone has the same experience or recognised what i describe...And Lollipop has these things also, or nada..?
                @scorp76: You can try my favorit combination. I use Wasser 3.0.3 and Kodi extracted from Ugoos UT3 v3.0.2b
                I have extracted this with Titanium Backup. On this Kodi version do not use the 23976 Codec. It is disabled by default
                * no sound dropouts, HD Sounds too
                * 3D is working (frame packaging)
                * 24p/23.976fps is very smoooth, no one judder e.g. (need enable: Adjust display refresh rate --> On start/stop and maybe Sync playback to display)
                * in 3D mode the icons for navigation are streched
                * I need in all movies a delay from 350ms. I have this set for all in advancedsettings.xml
                  Hi, I have a problem openning this streaming site "www.jepzo.com" I always get an error whatever browser I try, whereas it opens normally on my phone(sony andoird 5.1) and on my pc(win10)
                  Please can anyone try this site on their tv box and report here.
                  Ubox R89 2/16Go(5v4a) + Tv panasonic 32 Full HD + Airmouse c120 + 1To 2.5 Toshiba HD.
                    Hi All, marschmallow wasser firmware version 4.0.10 is released. For more infos, please take a look at the first post.
                    Enjoy and please don't forget to post feedbacks!
                    Thanks,
                    Wasser
                      Thanks,
                      Wasser
                      The requested URL /index.php was not found on this server.
                        Great news, thank you - but unable to download from the server.
                        Edit: Downloading now, thank you once more.
                          Hello Wasser,
                          Could You please post a Link to The latest RKMC you talk about in your first Post ...
                          3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
                          CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
                          Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
                          Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
                            michael2t
                            https://github.com/JamesLinEngineer/RKMC (official site)
                            rkmcapp-armeabi-v7a-debug.apk is the latest build
                              i installed version 4.0.10 yesterday and i can confirm that spdif passtrough worked on Superceleron kodi 16.1 RC2
                                Bud Cord rd rkmcapp i thought i could install it on marschmallow...Think i do something stupid, Apk cant be installed...This is an separate Rockchip media player..?Downloaded it but cant install it..Says something wrong with installation pack...?
