UPDATE - Marschmallow - Wasser Firmware for Beelink R89
    Originally posted by andreyh View Post
    I'd like to use HW mode because it is free of stuttering which is very critical for me. As you see I watch a lot of sport channels and it is very easy to notice frame drops during playback.
    Anyway, thanks, but it is not a solution for me.
    Have you tried the suggested use of HW+?
      Yes, sure, It stutters very often and in an addition a playback is not stable - it stops randomly. Very often it steps back to HW decoder or breaks a playback. Starting of playback and a rewind take much more time.
        Working pretty good now. Problem was on youtube the poor 1080p 60fps cuality that some guy uploaded, probably the editated program failed.
          Hello friends
          I will be glad if someone will be helpful to create account on www.4pda.ru for me. you can use this email address: [email protected] password 123456.
          Will be very grateful if some will give me a helping hand. thanks
            hi wasser, can embedded google play tv in firmware not, great if it appears
              isaybo, I created account for you on 4pda.ru , but I can't confirm it, because password for email is wrong. use link in the email. confirmation letter is in your inbox. BTW your PM is closed
                Thanks qwwwq
                  Hello, i've tested latest version of this ROM on my RKM MK902II. Remote controller doesn't work and audio passthrough doesn't work too. I am moving this Android box to my small TV in kitchen, so audio passthrough will not be important for me. But, if it's possible to make remote controller working, it will be fine.
                  Many thanks for this ROM, for my box is this the best ROM ever.
                    Hi Wasser!
                    I'm trying to explain again the interlacing issue in your latest firmware.
                    I succeeded to record a sample video describing the problem.
                    I'm using MX Player 1.7.40 in HW mode.
                    Screen resolution: 720p50. Auto-refresh rate is disabled.
                    For me it is only preventing issue for using your software.
                    Please, resolve it - it is so annoying.
                    Thanks!
                    please try to change the framerate to 25HZ. It should work better for you.
                      Hi Wasser!
                      Thanks for your reply.
                      My TV set doesnt support framerate 25HZ. It can be only 24, 50 or 60.
                      4.0.10 doesn't support interlaced modes although TV set does. (Another box shows them like 50i)
                      When it 24p on TV video jumps every second. In addition, a picture is not smooth as it was on 2.0.x
                      Please, add support for deinterlacing and I will donate another 20$ to you, because 4.0.10 is most stable and smooth software ever. It is worth it.
                        Hi! Just wonder if hdmi passthrough with Kodi works in this rom yet?
                          I testing Dolby Atmos and DTS:X passthru:
                          - On MXplayer:
                          Dolby Atmos play ok but if pause not return to play audio.
                          DTS:X not play
                          - On Kodi:
                          Dolby Atmos not play
                          DTS:X not play
                          I have a Denon X3300W, if necessary i post link it samples of files.
                          Obs. Tested in release 10
                            Note to All This is Wassers Thread on the BEELINK device. Not the rkm or the tronsmart or any other device. Please try and not post other devices issues in his thread its for the Beelink device. If the firmware doesnt work on your device Open a Thread in your device section and ask the question. You will notice Wasser responding to questions and concerns regarding issues on the device this software made for.
                            Wasser let us know if you want the thread cleaned of Hijack posts... Great work.
                              The Tronsmart R28 and Beelink R89 share the same boards inside and Wassers firmware has been compatible and used for a long time, with many comments and reviewing based upon both boxes.
                              So if there is an issue then I think it useful to have clarification from Wasser if he no longer wishes to receive feedback from people that have already been testing these firmwares successfully on the R28.
                                Yo Wasser! Just updated my r89 to marshmallow (since i got my pc i forgot my good old box) and damn, this is really smooth, a really nice update! Thanks man!
